šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • M5Dial RFID w/UIFLOW2
    3k Views
    robskiR
    uiflow2 alpha 29 has rfid in it now
  • Get properties of M5TextBox
  • Hola buenas tengo problemas para conectar mi M5 stick plus2 al wifi.
    1k Views
  • JSON decrypt of LORA868 in UIFLOW
  • "CanĀ“t convert NoneType to int" issue
    3k Views
    ajb2k3A
    Are you using a ā€œconvert to intā€ block to convert the value being sent to the dac?
  • ESPNow in UIFlow/MicroPython on M5StickC Plus2?
    3k Views
    S
    I too am extremely interested in this. I've been trying to program some wireless stuff on a couple of M5StickC Plus2s using UIFlow and ESP-Now... The only thing is I'm not seeing any ESP-Now options in the new UIFlow 2.0. There are block options in v 1.0 but when I use those I've been running into errors.
  • UART Equal function always returns false
    3k Views
    H
    Thank you for the reply, but I have already thought of that. the "decode" block removes everything other than the message (b'M105'\n -> M105)
  • UIFlow infinite loop and code reload
    3k Views
    P
    Hi @b0rscht , You should add this loop (yellow color) because it has included a 2ms delay or you use to while loop inside add the 2ms delay [image: 1702517364506-513b239c-addb-4a09-b0ae-ec00dce2a2bc-image.png] [image: 1702517691177-ba574b3e-88f1-4a38-9f15-096c2383c338-image.png] (OR) [image: 1702517302469-ac6155b5-dd37-48b7-93fe-99815c7185c3-image.png]
  • Help with ESP-Now and UiFlow on M5Stick C?
    3k Views
    S
    Hi @pandian-nano, Thanks! That was super helpful! That took care of the problem but now I'm getting the following error: "name 'now' isn't defined' Trying to figure out what's going on... it would be so fun to use ESP-Now on this thing :] I know I could probably use the arduino ide to do this, but I was just starting to get excited about UIFlow, it's pretty neat!
  • Blockey[CatM+GNSS Unit] , HTTP request
    3k Views
    C
    Sorry for my very late reply and Thank you a Screen shot. Kind people like you and UIFLOW updates solved my problem.
  • WiFi AP Connectivity UIFlow V2.0.0
    5k Views
    G
    @bergkatse I managed to resolve some of the issues that I was having and, implemented MQTT into my Core 2 monitoring. I stuck with UIFlow for this initial application to see how capable it was. It's not too bad however, I believe I will move to the Arduino IDE for more control. Here is the M5Stack Core 2 app that I created for your reference: [image: 1701112443929-cb317c54-58c7-404a-ae59-e84bf132f4c9-image-resized.png] I'm note sure if I implemented the WLAN functionality properly however, it works under all conditions. For example, if I exit the area of WiFi coverage, the connection resumes when I get back into range. Thank you
  • This topic is deleted!
  • Random Integer Problem
    3k Views
    H
    According to https://xkcd.com/221/ the random number should be 4 :-) In reality a randomizer will just be an algorithm to create numbers and often they get initialized by a timer. So if you always start the same code after reset and read the number it seems to met always the same initialisation. I miss a function to "randomize" the initialisation. Try to do it by any loop/function before that delays in a random way e.g. connection to wifi or read from a noisy AD channel until a specific value is read.
  • Transferring files from SD card in UIflow or...
    ajb2k3A
    @bergkatse unfortunately no as the limit is actually hardware. The S3 versions may be able to but not the older ones as they don’t have the USB mode architecture
  • M5StickC Plus EEPROM Issue UIFLOW
    P
    @kunal What is the real problem? Please explain in detail, we have tested it and it works on my side
  • Deploying UI Flow code to multiple devices - best practices/solutions??
  • RTC Error 19 help
    3k Views
    S
    Hi @pandian-nano Since I have written, it works fine… 🄸
  • Restart After Seconds...
    4k Views
    P
    Hi @cwdallas, We will update the new uiflow firmware version next week (Thursday) and every two weeks once
  • MQTT Issues
    5k Views
    C
    @pandian-nano Yes! thank you so much
  • json library error in uiflow
    7
    7k Views
    K
    @pandian-nano AHHH! Just figured it out. I had an old version of the burner program. I think I've got it now. Thank you!
