    Step Motor Module
    Units
    37.2k
    • C
      cepics
      thanks, some link to study waiting for goods?
        only this
        link text
        I have shared my sample code but my documentation need big work.
          BTW, you are aware that its the new year and everything is shut down thill the 12th?
          • C
            cepics
            @ajb2k3 said in Step Motor Module:
            @cepics said in Step Motor Module:
            thanks, I will try with NEMA 17 12v.....
            You will need to adjust the drivers as they are not calibrated by default.
            How can I calibrate the drivers?
            Can I Use this motor?
            • Angle of step: 1.8 degrees.
            • Voltage: 12 V
            • Current: 1.2 A / phase.
            • Resistance: 10.0 ± 10% / phase.
            • inductance: 20 ± 20% / phase.
            • Support moment: 68 g / cm2.
            • Number of wires: 4
            • Support time: 48 min. N. cm.
            • Large braking torque: 2.6 N. cm.
            • Insulation class: B
              Ebay link?
              Calibration is done via the tiny silver round thing on the individual stepper driver.
              • C
                cepics
                Ebay link?
                NEMA 17 MOTOR
                thanks a lot !!
                something like this ?
                  Yes, just like that.
                  Don't connect any steppers when calibrating it!
                  • C
                    cepics
                    NEMA 17 MOTOR
                    can I use this motor with the step motor module?
                    can I power the core and the module with 12v ?
                      ajb2k3 @cepics
                      @cepics
                      yes the nema 17 will be fine.
                      I'm sure that the m5 will receive power from the module but i'm not certain.
                      you will need external power to the module to power the stepper.
                      • C
                        cepics
                        I will try ....
                        thanks
                        • K
                          Kryten
                          @ajb2k3 Do you have any good scource for wires for the stepper output?
                          I have several sets of stepper motor wires but none that fit in the stepper module
                            ajb2k3 @Kryten
                            @kryten the stepper module uses the standard Grove cable system so cutting off the existing wire connections on the stepper motor and replacing them with a grove wire harness works fine for me.
                            • K
                              Kryten @ajb2k3
                              Thank you very much.
                              I hope to get some wires sorted out soon so I can see if I manage to get the module working on a "printer" (2D drawings)
                                ajb2k3 @Kryten
                                @kryten said in Step Motor Module:
                                My pleasure
                                • C
                                  cepics
                                  can I use this motor with this module?
                                    ajb2k3 @cepics
                                    It looks like it should work but you would need to adjust the drivers. I don’t have one so I can’t say for certain but it is a 4 wire stepper
