    Step Motor Module
    Units
    38.8k
      Yes, just like that.
      Don't connect any steppers when calibrating it!
      • C
        cepics
        @cepics said in Step Motor Module:
        NEMA 17 MOTOR
        can I use this motor with the step motor module?
        can I power the core and the module with 12v ?
          ajb2k3 @cepics
          @cepics
          yes the nema 17 will be fine.
          I'm sure that the m5 will receive power from the module but i'm not certain.
          you will need external power to the module to power the stepper.
          • C
            cepics
            I will try ....
            thanks
            • K
              Kryten
              @ajb2k3 Do you have any good scource for wires for the stepper output?
              I have several sets of stepper motor wires but none that fit in the stepper module
                ajb2k3 @Kryten
                @kryten the stepper module uses the standard Grove cable system so cutting off the existing wire connections on the stepper motor and replacing them with a grove wire harness works fine for me.
                • K
                  Kryten @ajb2k3
                  Thank you very much.
                  I hope to get some wires sorted out soon so I can see if I manage to get the module working on a "printer" (2D drawings)
                    ajb2k3 @Kryten
                    @kryten said in Step Motor Module:
                    My pleasure
                    • C
                      cepics
                      can I use this motor with this module?
                        ajb2k3 @cepics
                        It looks like it should work but you would need to adjust the drivers. I don’t have one so I can’t say for certain but it is a 4 wire stepper
