    Step Motor Module
    20 Posts 3 Posters 42.5k Views 1 Watching
      Ebay link?
      Calibration is done via the tiny silver round thing on the individual stepper driver.
        cepics
        @ajb2k3 said in Step Motor Module:
        Ebay link?
        NEMA 17 MOTOR
        thanks a lot !!
        something like this ?
          Yes, just like that.
          Don't connect any steppers when calibrating it!
            cepics
            @cepics said in Step Motor Module:
            NEMA 17 MOTOR
            can I use this motor with the step motor module?
            can I power the core and the module with 12v ?
              ajb2k3 @cepics
              @cepics
              yes the nema 17 will be fine.
              I'm sure that the m5 will receive power from the module but i'm not certain.
              you will need external power to the module to power the stepper.
                cepics
                I will try ....
                thanks
                  Kryten
                  @ajb2k3 Do you have any good scource for wires for the stepper output?
                  I have several sets of stepper motor wires but none that fit in the stepper module
                    ajb2k3 @Kryten
                    @kryten the stepper module uses the standard Grove cable system so cutting off the existing wire connections on the stepper motor and replacing them with a grove wire harness works fine for me.
                      Kryten @ajb2k3
                      Thank you very much.
                      I hope to get some wires sorted out soon so I can see if I manage to get the module working on a "printer" (2D drawings)
                        ajb2k3 @Kryten
                        @kryten said in Step Motor Module:
                        My pleasure
                          cepics
                          can I use this motor with this module?
                            ajb2k3 @cepics
                            It looks like it should work but you would need to adjust the drivers. I don’t have one so I can’t say for certain but it is a 4 wire stepper
