    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 247.7k Views 6 Watching
      TomSuch @kaotiklabs
      @kaotiklabs Hi, Thank you for the subject. I will look at it.
      For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
      http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
        TomSuch @m5stack
        @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
        • reaper7R Offline
          reaper7
          Accu meter app (MAX17043 module soldered inside Battery Module)
          T JJJ 2 Replies Last reply Reply Quote 3
            TomSuch @reaper7
            @reaper7 Good work, thank you ...
            • JJJ Offline
              JJ @reaper7
              @reaper7
              Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                TomSuch
                A new version of the M5StackSAM library
                https://github.com/tomsuch/M5StackSAM
                Added features to easily create and navigate the list.
                (APPLICATIONS -> LIST DEMO)
                Added support for the FACES QWERTY keyboard.
                (APPLICATIONS -> FACES GET STRING)
                • JJJ Offline
                  JJ @TomSuch
                  @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                    sheepDog
                    what version/type of wire.h do you use?
                    I got this error at "Wire.requestFrom(0x08,1,true);":
                    In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                     from sketch/M5StackSAM.h:1,
                                     from sketch/M5StackSAM.cpp:1:
                    /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                    /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                         uint8_t requestFrom(int, int, int);
                    /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                         size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                    Can anyone help me?
                    • W Offline
                      wschnell @SunWukong
                      @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                      • W Offline
                        wschnell @SunWukong
                        found it - it's a Seeed Studio Wrapper
                          TheAlphaGhost
                          Hi Guys,
                          ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                          How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                          Can anyone help me ?
