    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 250.1k Views 6 Watching
    • JJJ Offline
      JJ @TomSuch
      @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
        TomSuch @JJ
        @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
        https://github.com/tomsuch/M5Stack-SAM/
        • JJJ Offline
          JJ @TomSuch
          @tomsuch
          Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
            TomSuch @JJ
            @jimit No problem Jim. Regards....
              kaotiklabs
              Would be awesome to have a generic menu system so you could focus only on core development.
              I have tried to use yours for my app but had no time to fully understand it.
              Could you write a little doc explaining how can we use it in our apps?
              • SunWukongS Offline
                SunWukong @TomSuch
                @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                  TomSuch
                  @sunwukong Hi, Thank you for the subject. I will look at it.
                  For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                  http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                    TomSuch @kaotiklabs
                    @kaotiklabs Hi, Thank you for the subject. I will look at it.
                      TomSuch @m5stack
                      @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                      • reaper7R Offline
                        reaper7
                        Accu meter app (MAX17043 module soldered inside Battery Module)
                        T JJJ 2 Replies Last reply Reply Quote 3
                          TomSuch @reaper7
                          @reaper7 Good work, thank you ...
                          • JJJ Offline
                            JJ @reaper7
                            @reaper7
                            Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                              TomSuch
                              A new version of the M5StackSAM library
                              https://github.com/tomsuch/M5StackSAM
                              Added features to easily create and navigate the list.
                              (APPLICATIONS -> LIST DEMO)
                              Added support for the FACES QWERTY keyboard.
                              (APPLICATIONS -> FACES GET STRING)
                              • JJJ Offline
                                JJ @TomSuch
                                @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                                  sheepDog
                                  what version/type of wire.h do you use?
                                  I got this error at "Wire.requestFrom(0x08,1,true);":
                                  In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                                   from sketch/M5StackSAM.h:1,
                                                   from sketch/M5StackSAM.cpp:1:
                                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                                       uint8_t requestFrom(int, int, int);
                                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                                       size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                                  Can anyone help me?
                                  • W Offline
                                    wschnell @SunWukong
                                    @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                                    • W Offline
                                      wschnell @SunWukong
                                      found it - it's a Seeed Studio Wrapper
                                        TheAlphaGhost
                                        Hi Guys,
                                        ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                                        How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                                        Can anyone help me ?
