    How do you change volume on Core2
    7 Posts 3 Posters 14.4k Views
      SE
      Under "Speaker" in UIFLOW there is the ability to play wave files but the next step is to obviously change volume. Does anyone know how to change volume on a Core2 in UIFLOW or Python?
      • ZontexZ Offline
        Zontex
        Hello, under hardware -> speaker -> there is a block called "setVolume" that you can use to change the volume of your Core device :)
        • B Offline
          bobolink
          Is there a C/C++ way to set volume?
            SE
            On the Grey Core UIFLOW there is a volume command but on under the CORE2 Beta UIFLOW I cannot find one. Here is a screenshot. Let me know what you think. Thanks 0_1611854426492_image_2021-01-28_122026.png
            • ZontexZ Offline
              Zontex @SE
              @se Hi, This is core2 not grey, core2 doesn't support for now due to some bug we have to resolve that makes background noise. if you try normal core it will work just fine.
              @bobolink currently we don't support C/C++ API for it.
              • B Offline
                bobolink @Zontex
                @zontex OK thanks for the reply. I guess you could set the volume of the .WAV files in the pc program “Audacity”.
                But user volume control would be nice.
                • B Offline
                  bobolink @bobolink
                  @bobolink FYI to myself
                  If you have an engineering background--part of Micropython--
                  module 'dba: calculate dBA (A-weighting decibels) from an input stream of digital audio samples
                  module 'i2stools': function to efficiently extract sample data from a buffer filled by I2S
                  Signal processing (logical shifts--fractional multiply) on the PCM samples instead of hardware volume control gets the job done also.
