    How to flash tasmona or anything to M5Stack ATOM Lite using esptool?
    Units
    6
    13.0k
    • R
      romeokienzler
      Hi, I've tried so many things, but what is the correct way to flash a firmware to the M5Stack ATOM Lite ESP32 Development Kit using esptool? This (among many other commands) is not working
      esptool.py --chip auto --port /dev/ttyUSB0 --baud 115200 --before default_reset --after hard_r^Cet write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 /home/romeokienzler/Downloads/tasmota32.bin
      When I look at the serial monitor of the arduino IDE i get
      11:10:25.593 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      11:10:25.593 -> configsip: 188777542, SPIWP:0xee
      11:10:25.593 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      11:10:25.593 -> mode:DIO, clock div:2
      11:10:25.593 -> load:0x3f400020,len:289900
      11:10:25.958 -> ets Jun 8 2016 00:22:57 (edited)
        Hello @romeokienzler
        M5Atom lite essentially is just another ESP32 based device so I'd guess the regular Tasmota instructions should work (not tested myself though). Have you tried the instructions here?
        Good luck!
        • world101W
          world101 @romeokienzler
          @romeokienzler said in How to flash tasmona or anything to M5Stack ATOM Lite using esptool?:
          after hard_r^Cet
          Just to point out a possible issue, it looks I like you have a Control-C in your command by mistake. Is that a copy/paste error?
          • R
            romeokienzler
            Dear @felmue and @world101 - I've followed the published instructions and also the ^C is only present in the post thanks for pointing that out. So until now I don't have a solution to my problem...
            • R
              romeokienzler
              Checking out Stackoverflow now :) https://stackoverflow.com/questions/66514659/how-to-flash-tasmota-or-anything-to-m5stack-atom-lite-esp32-pico-d4-using-es
              • DR_Froggy_rDD
                DR_Froggy_rD
                I have alsoo a problem with esptool
                File "esptool\cmds.py", line 94, in detect_chip
                File "esptool\loader.py", line 378, in check_command
                File "esptool\loader.py", line 347, in command
                File "esptool\loader.py", line 279, in read
                File "esptool\loader.py", line 1387, in slip_reader
                esptool.util.FatalError: Serial data stream stopped: Possible serial noise or corruption.
                During handling of the above exception, another exception occurred:
                File "esptool.py", line 34, in <module>
                File "esptool_init_.py", line 995, in main
                File "esptool_init
                .py", line 637, in main
                File "esptool_init_.py", line 880, in get_default_connected_device
                File "esptool\cmds.py", line 121, in detect_chip
                File "esptool\loader.py", line 603, in connect
                File "esptool\loader.py", line 544, in _connect_attempt
                File "esptool\loader.py", line 407, in sync
                File "esptool\loader.py", line 323, in command
                File "serial\serialutil.py", line 372, in timeout
                File "serial\serialwin32.py", line 222, in _reconfigure_port
                serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
                [6352] Failed to execute script 'esptool' due to unhandled exception!
                before clicking the burn button on m5burner, I push the button to enter boot mode green led is flashing
