    The Max value of the slider cannot be modified !
    5 Posts 3 Posters 9.8k Views 1 Watching
    • ArnoA Offline
      Arno
      The Max value of the slider in Uiflow 1.7.2 does not work, whatever the value indicated, it remains at 100.
      Would it be possible to have vertical sliders and the possibility of also modifying the color of the cursor?
        ksprayberry
        Can you flip to the code side and modify it right before you upload it to the controller? I know this is a bug report, but that might be a good work around till they can fix it.
        • ArnoA Offline
          Arno
          the problem is still present in version 1.7.4 with Uiflow !
          • world101W Offline
            world101
            Yes, I agree this is a bug with the slider object and also the bar object in the UI simulator, but you can easily work around the bug with the Set range min max block until m5stack fixes it.
            • ArnoA Offline
              Arno
              Perfect !
