m5stack unitv2 AI Camera - getting started
Just arrived. When I plug into a Windows 10 machine I see a device called USB 10/100 LAN with the yellow warning triangle. So no driver. Where do I find the driver, please?
Also, by default should I be able to access the device via WiFI on the SSID M5UV2_XXXX ? I see no such SSID being broadcast.
Thanks!
Pat
check the tutorial you will get the driver
https://docs.m5stack.com/en/quick_start/unitv2/base_functions
same issue for me, the device didn’t broadcast any WiFi. I can only connect via the USB ethernet Lan.
Also, Is there a way to use the USB network adapter on OSX system?
Same issue, im running a mac so i think hotspot connectivity is my only choice and im having same issue the wifi network is not available to connect ?
I can’t see the ssid from my side. anything to active on the unit?
any chance to get the driver for macOSX?
Maybe for Mac os this is the driver http://www.corechip-sz.com/endownload.asp
"SR9900 MacOS Big Sur Driver"
Its not available to download for normal user.
Thanks. Alex
Hi allk. Same for me no Ap is broadcasted. Can ssh to the unit via 10/100 USB-LAN, but sudo is not working so even when finding the configuration for WLAN I think its not possible to change.
we debug these issues now. we will release the new firmware update to fix it later.
@m5stack ok thank for the update. do you have a expected release date for the next firmware with wifi?
@nechry not yet. sorry. when we update it , we will public a post to the community.
Having a similar issue, I've got into the web server, but the AP isn't starting, I can't even find the AP ID or even tell if it's started?
