    UIFlow 1.8.0
    31 Posts 11 Posters 89.8k Views 2 Watching
    • OyczEO Offline
      OyczE
      Hello @m5stack
      #1
      looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
      Simple remove 'from m5stack_ui import *' fix the problem
      #2
      Plus AtomLora DUT error ..
      File "flow/m5cloud.py", line 82, in _exec_fun
      File "<string>", line 3, in <module>
      ImportError: no module named 'base.DTU_LoRAWAN'
      #3
      LoraWan868 + Core2
      'module' object has no attribute 'LORAWAN'
      Do we have any LoraWan support in 1.8.0 ?!
      Regards
      Mati
        deathvedar
        We tried to run the LoRaWAN 868 Unit with absolut no luck.
        If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
        please, please fix this ASAP!
        • OyczEO Offline
          OyczE
          @m5stack could we get reply about uiflow support for lorawan ?
          • m5stackM Online
            m5stack @OyczE
            @mati you could try 0001 for the mask code
            • m5stackM Online
              m5stack @OyczE
              @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
              OyczEO 2 Replies Last reply Reply Quote 0
              • OyczEO Offline
                OyczE @m5stack
                @m5stack indeed it was two tabs !
                Let me check this, thx for a hint.
                  tnkmasayuki
                  I can't stop the sound.
                  UIFlow1.8.0 + M5StickC Plus
                    stefanj9
                    Wher can I find version 1.8.0?
                    • OyczEO Offline
                      OyczE @stefanj9
                      • OyczEO Offline
                        OyczE @m5stack
                        @m5stack hmm no luck one tab and still error
                        but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                        from base.DTU_LoRAWAN import DTU_LoRAWAN
                        into
                        from base.DTU_LoRaWAN import DTU_LoRaWAN
                          plusulli
                          In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                          • m5stackM Online
                            m5stack @plusulli
                            @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                            • m5stackM Online
                              m5stack @OyczE
                              @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                              • OyczEO Offline
                                OyczE @m5stack
                                @m5stack said in UIFlow 1.8.0:
                                This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                                And what a supprise its fixed now ;)
                                Day ago was
                                what a nice silent fix =]
                                  plusulli
                                  in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
