    UIFlow 1.8.3
    7 Posts 6 Posters 12.6k Views 1 Watching
    • m5stackM Online
      Ver 1.8.3 time: 2021.0827
      v1.8.3
      new features:
      • Add UNIT FADER support
      • Add Module stepmotor driver support
      • ESP-NOW support encrypt(LMK)
      • New Vfunciton for UNIT V2
      Bug fix:
      • Fix NB-IoT MQTT downlink data parse error
      • Fix ATOM-DTU Modbus UART ID error
        mory
        good job! when will the desktop IDE be upgraded?
          RGB leds won't work on M5Stamp if pins set to anything other that PORTA
            dominiclee
            I am beginner of M5Stack. I bought both M5Go and Fire, together with lots of units. When I test the OLED unit, I found it always show M5 logo with "M5STACK". i can 't fill with black or white. I can't draw rect. I can't draw line. I can't draw text. The only function works is "invert" but still only M5 logo with "M5STACK" is shown all the time. I tested it with both M5Go and Fire but same problem. Any help?
              plusulli
              with uiflow the OLED-unit shows nothing else than the M5Stack logo
              • m5stackM Online
                m5stack @plusulli
                @plusulli
                add this block after any draw.
                0_1630304660563_73219f06-91bc-48ac-8f1e-f1b2d2ef6353-44efba0b920b2bfd9c9209c1ab29b48.jpg
                • saitotetsuyaS Offline
                  saitotetsuya
                  The range of ids of the Set id block in myCobot is wrong. It should be from 1 to 6, but from 2 to 7.
