UIFlow 1.8.9
v1.8.9
new features:
- ZH-CN:
- MQTT PRINTER 支持
- SMART CONFIG 支持
- EN:
- MQTT PRINTER support
- SMART CONFIG support
- ZH-CN:
ATOM Display and the C3 !
after switching to German I can not use Uiflow
After that I have to clear the browser cache so that Uiflow starts again
with the English versionwhat is Smart Config Support?
due hope for a C3 support I have given up
@plusulli The C3 is so new that the Core Micropython doesn't fully support it yet!
Hi, Do you think to update the desktop version soon to match a little bit with functions available in the beta v1.8.9?
FYI, also the web version is 1.4.5, far away from the current desktop version v1.7.4...
Thx by advance for you quick repply ;-) -
@plusulli thank you feedback. now it fixed.
@arno Still need to wait for a while
Hello @m5stack
thank you for fixing the font issue on M5Core2, which occurred in the previous UIFlow version 1.8.8., while downloading a program into the M5Core2. I appreciate it.
Felix -
@m5stack I bought the ATOM DISPLAY and the C3 for a while. I hope that the use with Uiflow will be operational quickly.
I am falling behind on my projects and this is not the first time that Uiflow has not been available with the product. -
@m5stack
I'm using CoreInk and i want realize a menu with a selection indicator.
This is part of the sketch i'm using:I think there's a bug in M5Line when redraw because this is what i get:
https://drive.google.com/file/d/1kE_-J3Zrc57fYtHJqEOPY6LEf_pZhMYL/view?usp=sharingThe problem occurs also if i call a complete refresh instead of partial.
M5Rect has the same problem, M5Circle works fine. -
I have updated to this version my core2 with faces keyboard, and the led are bright at 100%. I have not been able to stop them.
