    ENV III unit on M5Stack CoreInk
    Units
    7
    9.1k
    • A
      aafortinet
      Very n00b question, but how do I use the ENV III sensor on CoreInk? T
      From sample code https://docs.m5stack.com/en/unit/envIII, I tried this but UNIT_ENV.h does not exist on CoreInk
      #include "M5CoreInk.h"
      #include "UNIT_ENV.h"
      SHT3X sht30;
      QMP6988 qmp6988;
      Same #include "M5_ENV.h" does not exist either.
      Thanks.
      • A
        aafortinet
        Ok - I found. You have to use #include "M5_ENV.h" and include the library M5UNIT-ENV in Arduino.
        • V
          vuhn88
          Not sure if you're referring to the hat or port ENV III but the get method of SHT3X didn't have the correct begin for the ENV III hat, so I brought the method into main and manually set up Wire.begin(25, 26) as seen below:
          #include "M5_ENV.h"
          //SHT3X sht30;
          QMP6988 qmp6988;
          float tmp      = 0.0;
          float hum      = 0.0;
          float pressure = 0.0;
          Ink_Sprite InkPageSprite(&M5.M5Ink);
            Wire.begin(25, 26);
            qmp6988.init();
            if ( !M5.M5Ink.isInit()) {
              Serial.printf("Ink Init faild");
              while (1) delay(100);
            M5.M5Ink.clear();   //Clear screen.
            delay(1000);
            if ( InkPageSprite.creatSprite(0, 0, 200, 200, true) != 0) {
              Serial.printf("Ink Sprite creat faild");
          byte getVal()
            unsigned int data[6];
            // Start I2C Transmission
            Wire.beginTransmission(0x44);
            // Send measurement command
            Wire.write(0x2C);
            Wire.write(0x06);
            // Stop I2C transmission
            if (Wire.endTransmission() != 0)
              return 1;
            delay(200);
            // Request 6 bytes of data
            Wire.requestFrom(0x44, 6);
            // Read 6 bytes of data
            // cTemp msb, cTemp lsb, cTemp crc, humidity msb, humidity lsb, humidity crc
            for (int i = 0; i < 6; i++) {
              data[i] = Wire.read();
            delay(50);
            if (Wire.available() != 0)
              return 2;
            // Convert the data
            float cTemp = ((((data[0] * 256.0) + data[1]) * 175) / 65535.0) - 45;
            tmp = (cTemp * 1.8) + 32;
            hum = ((((data[3] * 256.0) + data[4]) * 100) / 65535.0);
            return 0;
            pressure = qmp6988.calcPressure();
            if (getVal() == 0) {
              char buf[20];
              snprintf(buf, 20, "Temp: %2.1f F", tmp);
              InkPageSprite.drawString(40, 20, buf);
              snprintf(buf, 20, "Humi: %2.0f%%", hum);
              InkPageSprite.drawString(40, 40, buf);
              snprintf(buf, 20, "Pres: %2.0f Pa", pressure);
              InkPageSprite.drawString(40, 60, buf);
            InkPageSprite.pushSprite(); //Push the sprite to the screen.
            delay(1000);
          It's pretty basic in functionality, but it works for the most part. And again, this is for the ENV III hat.
          • teastainT
            teastain @vuhn88
            @vuhn88 Good to know! I also tried last week to run an ENVII on Stamp-C3 but the "get" didn't get! So I put the code inline as you did and it worked fine, then I wrote a new library (with the proven inline code) as a function with Return (value) and that worked as well. (just completed last night!)
            The "get" is somehow the problem. Cheers!
              As you have noticed, "Get" isn't a stand alone function instead it is used to retrieve values and so is required to be used with a function.
              • teastainT
                teastain @ajb2k3
                @ajb2k3 The std ENV Library works with Stamp-PICO, but not Stamp-C3.
                The GET works with PICO, not C3.
                Bringing the library code into the Arduino void loop() works for both products.
                I re-wrote the standard library to remove the GET and instead used this:
                #include <SHT3Xnew.h>
                unsigned int data[2];
                float sensor() {
                Wire.write(0x2C);
                Wire.write(0x06);
                if (Wire.endTransmission() != 0) {
                Serial.println("not = 0 ");
                delay(50);
                Wire.requestFrom(0x44, 2);
                data[0] = Wire.read();
                data[1] = Wire.read();
                delay(50);
                return ((((data[0] * 256.0) + data[1]) * 175) / 65535.0) - 45;
                This Library works with both, but is just a test, only reads cTemp, ;)
                  ajb2k3 @teastain
                  @teastain Nice work.
