ENV III unit on M5Stack CoreInk
Very n00b question, but how do I use the ENV III sensor on CoreInk? T
From sample code https://docs.m5stack.com/en/unit/envIII, I tried this butUNIT_ENV.h
does not exist on CoreInk#include "M5CoreInk.h" #include "UNIT_ENV.h" SHT3X sht30; QMP6988 qmp6988;
Same
#include "M5_ENV.h"
does not exist either.
Thanks.
Ok - I found. You have to use
#include "M5_ENV.h"
and include the library M5UNIT-ENV in Arduino.
Not sure if you're referring to the hat or port
ENV III
but theget
method ofSHT3X
didn't have the correctbegin
for theENV III
hat, so I brought the method into main and manually set upWire.begin(25, 26)
as seen below:#include "M5CoreInk.h" #include "M5_ENV.h" //SHT3X sht30; QMP6988 qmp6988; float tmp = 0.0; float hum = 0.0; float pressure = 0.0; Ink_Sprite InkPageSprite(&M5.M5Ink); void setup() { M5.begin(); Wire.begin(25, 26); qmp6988.init(); if ( !M5.M5Ink.isInit()) { Serial.printf("Ink Init faild"); while (1) delay(100); } M5.M5Ink.clear(); //Clear screen. delay(1000); if ( InkPageSprite.creatSprite(0, 0, 200, 200, true) != 0) { Serial.printf("Ink Sprite creat faild"); } } byte getVal() { unsigned int data[6]; // Start I2C Transmission Wire.beginTransmission(0x44); // Send measurement command Wire.write(0x2C); Wire.write(0x06); // Stop I2C transmission if (Wire.endTransmission() != 0) return 1; delay(200); // Request 6 bytes of data Wire.requestFrom(0x44, 6); // Read 6 bytes of data // cTemp msb, cTemp lsb, cTemp crc, humidity msb, humidity lsb, humidity crc for (int i = 0; i < 6; i++) { data[i] = Wire.read(); }; delay(50); if (Wire.available() != 0) return 2; // Convert the data float cTemp = ((((data[0] * 256.0) + data[1]) * 175) / 65535.0) - 45; tmp = (cTemp * 1.8) + 32; hum = ((((data[3] * 256.0) + data[4]) * 100) / 65535.0); return 0; } void loop() { pressure = qmp6988.calcPressure(); if (getVal() == 0) { char buf[20]; snprintf(buf, 20, "Temp: %2.1f F", tmp); InkPageSprite.drawString(40, 20, buf); snprintf(buf, 20, "Humi: %2.0f%%", hum); InkPageSprite.drawString(40, 40, buf); snprintf(buf, 20, "Pres: %2.0f Pa", pressure); InkPageSprite.drawString(40, 60, buf); } InkPageSprite.pushSprite(); //Push the sprite to the screen. delay(1000); }
It's pretty basic in functionality, but it works for the most part. And again, this is for the
ENV III
hat.
@vuhn88 Good to know! I also tried last week to run an ENVII on Stamp-C3 but the "get" didn't get! So I put the code inline as you did and it worked fine, then I wrote a new library (with the proven inline code) as a function with Return (value) and that worked as well. (just completed last night!)
The "get" is somehow the problem. Cheers!
As you have noticed, "Get" isn't a stand alone function instead it is used to retrieve values and so is required to be used with a function.
@ajb2k3 The std ENV Library works with Stamp-PICO, but not Stamp-C3.
The GET works with PICO, not C3.
Bringing the library code into the Arduino void loop() works for both products.
I re-wrote the standard library to remove the GET and instead used this:
#include <SHT3Xnew.h>
unsigned int data[2];
float sensor() {
Wire.write(0x2C);
Wire.write(0x06);
if (Wire.endTransmission() != 0) {
Serial.println("not = 0 ");
delay(50);
Wire.requestFrom(0x44, 2);
data[0] = Wire.read();
data[1] = Wire.read();
delay(50);
return ((((data[0] * 256.0) + data[1]) * 175) / 65535.0) - 45;
}This Library works with both, but is just a test, only reads cTemp, ;)
@teastain Nice work.
