    Maximum recursion depth?
    11 Posts 6 Posters 18.7k Views 1 Watching
      dclaar
      Sometimes I get a stack dump almost immediately on starting the network, so maybe I'm skating close to the edge.
      Connected. Network config: ('192.168.6.109', '255.255.255.0', '192.168.6.1', '192.168.6.1')
      ***ERROR*** A stack overflow in task mp_thread has been detected.
      abort() was called at PC 0x400899a8 on core 1
      ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
      Backtrace: 0x400896a7:0x3ffb9160 0x40089991:0x3ffb9180 0x400899a8:0x3ffb91a0 0x4009220a:0x3ffb91c0 0x40093f98:0x3ffb91e0 0x40093f4e:0x3ffb91cc
      • m5stackM Online
        could you provide your code?
          dclaar
            dclaar
            I decided to go to a polling loop instead and it seems to work a lot better.
              crami25
              @dclaar
              See https://www.geeksforgeeks.org/python-handling-recursion-limit/ :
              by default, the value normally is 10^4.
                dclaar
                As I'm not doing recursion explicitly, there must be something going on behind the scenes. Or I've got an error! Or maybe event-driven isn't clean and somehow keeps calling itself.
                  SAbadshah
                  Since I'm not expressly using recursion, something else must be happening. Or I made a mistake! Or perhaps event-driven isn't clean and keeps naming itself in some way[url=https://mybankinginformation.com/citibank-routing-number/].[/url]
                    SAbadshah @SAbadshah
                    Instead, I choose to switch to a polling loop, and it seems to function much better.
                      KirkSutton23
                      Instead, I switched to a polling loop, which seemed to work much better.
                      • teastainT Offline
                        teastain @KirkSutton23
                        Rather, I chose to switch to polling, which worked much better, so it seems.
