    CM4 Stack Issues from the very start.
    3 Posts 2 Posters 2.9k Views
      @m5stack @IAMLIUBO
      I have just started on the CM4 and already have issues.
      1, The info display on the actual screen has vanished after update,
      2, The clock example on GitHub does not work on a fresh CM4 Stack
      • teastainT Offline
        teastain @ajb2k3
        @ajb2k3 is that the https://github.com/m5stack/CM4Stack_lvgl/blob/Basic/main.cpp
        Or something else?
          No it was from this place:
          https://github.com/m5stack/m5stack-linux-dtoverlays/tree/main/examples
          The issue is actually a dependence missing from the install instructions (user writeup error) fixed with adding the following command:
          sudo apt-get install qtdeclarative5-dev
          before running
          cmake .. && make
