    LAN W5500 socket listening does not work
    5 Posts 3 Posters 6.9k Views
    • M5StickFreaklerM Offline
      M5StickFreakler
      Hi friends
      I have written a simply micropython test program as a web server.
      It works when I am using the configured ip address of wifi connection (ip via dhcp).
      Then I have tried the LAN base module W5500 V12.
      Unfortunately it does not work with the configured ip address of the ethernet module (ip via dhcp) .
      I have used....
      lan = module.get(module.LANBASE)
      ...instead of...
      lan = network.LAN(mdc=23, mdio=18, power=21, phy_type=network.PHY_W5500, phy_addr=0)
      lan.active(True)
      ...because I get an error message that network does not support LAN methode.
      Here is my micropython example code:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import wifiCfg
      import network
      import socket
      import module
      #WiFi
      wifiCfg.screenShow()
      wifiCfg.autoConnect(lcdShow=True)
      wifiIp = wifiCfg.wlan_sta.ifconfig()[0]
      title0 = M5Title(title="SERVER-EXAMPLE", x=95, fgcolor=0xFFFFFF, bgcolor=0xff001d)
      label0 = M5TextBox(10, 40, "WiFi ip :" + str(wifiIp), lcd.FONT_Ubuntu, 0xfff500, rotate=0)
      #Ethernet
      #lan = network.LAN(mdc=23, mdio=18, power=21, phy_type=network.PHY_W5500, phy_addr=0)
      #lan.active(True)
      eth0Ip = lan.get_if_config()[0]
      label1 = M5TextBox(10, 60, "Eth0 ip :" + str(eth0Ip), lcd.FONT_Ubuntu, 0xfff500, rotate=0)
      #Choose ip address
      ip = wifiIp # works
      #ip = eth0Ip # does not work
      #Socket binding
      sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
      sock.bind((ip, 80))
      label2 = M5TextBox(10, 80, "SERVER running at " + ip, lcd.FONT_Ubuntu, 0xfff500, rotate=0)
      #Listening
      sock.listen(1)
      while True:
      conn, addr = sock.accept()
      print('Connection from:', addr)
      conn.sendall('Hello, world!')
      conn.close()
      • felmueF Online
        Hello @M5StickFreakler
        have you tried the example? It works for me.
        Note: the Init LAN block blocks until a client connects.
          M5StickFreakler
          Hi felmue
          Thanks for your appreciated reply.
          Unfortunately it is unusable for me in that way. I would like to bind the ip address to a socket on port 80 (http server). And I dont want that the application is blocked until a client connects.
          best regards
            M5StickFreakler
            tried with modified code, but no luck:
            from m5ui import *
            import wifiCfg
            import network
            import socket
            import module
            #WiFi
            counter = 0
            #Ethernet
            lan.tcp_udp_config(eth0Ip, 80, 1, 1) ## es muss ein call gemacht werden, damit das Programm weiter läuft
            #Choose ip address
            #ip = wifiIp # works
            label2 = M5TextBox(10, 80, "SERVER is running", lcd.FONT_Ubuntu, 0xfff500, rotate=0)
            label3 = M5TextBox(10, 100, "waiting...", lcd.FONT_Ubuntu, 0xfff500, rotate=0)
            label4 = M5TextBox(10, 120, "received?", lcd.FONT_Ubuntu, 0xfff500, rotate=0)
            if ip == wifiIp:
            server = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            server.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
            server.settimeout(30)
            server.bind((wifiIp, 80))
            while True:
                server.listen(1)
                (conn, addr) = server.accept()
                request = conn.recv(4096)
                if request:
                    counter = counter + 1
                    request = str(request)
                    conn, addr = server.accept()
                    label3.setText(str(counter))
                    label4.setText(str(request))
                    response = 'Hello, world!'
                    conn.sendall(response)
                    conn.close()
                wait_ms(2)
            if ip == eth0Ip:
            while True:
                if lan.is_available_packet(1):
                    request = str(lan.tcp_receive_packet(0))
                    lan.tcp_send_packet(response)
                wait_ms(2)
              Treadbrook @M5StickFreakler
              @m5stickfreakler hi - did you ever solve this? I am having the same problem with both the LAN Module and the LAN Base - it initialises the LAN, gets an IP address, but just won't accept data from a browser when I try the following code:
              s = socket.socket()
              s.bind(('172.17.15.87',80))
              s.listen(1)
              I would love to get this sorted!
              Cheers,
