    Optical stepper motor test.
    PRODUCTS
    6.4k
      This is my code for testing optical drive stepper motors.
      alt text
        Please note that when using these drives the vref need to be just above the point where it stops the motors otherwise the motors overheat
          Also from what I can tell, they have a Steps Per Revolution of 20 (18 degree steps)
          • m5-docsM
            m5-docs @ajb2k3
            Hello,I can not get your code in this post.
            M5Stack documentation URL
            https://docs.m5stack.com
              Blocky code is so simple that not provide a download.
                ajb2k3 @m5-docs
                @watson said in Optical stepper motor test.:
                You also need to tune the drives way down low as it causes to steppers to overheat
