    Core S3 SE images won't show
    11 Posts 4 Posters 7.9k Views 1 Watching
    • greenleafG Offline
      greenleaf @greenleaf
      @greenleaf Here's a screenshot. I've tried both a small PNG image and a small JPG image. Neither one ever shows up on the screen.
      (screenshot.png image url)
      J felmueF 2 Replies Last reply Reply Quote 0
        jeanfabre @greenleaf
        @greenleaf I have the exact same problem on the m5dial (https://community.m5stack.com/topic/6829/can-t-get-m5dial-to-display-an-image-loaded-via-uiflow2). I hope someone is going to reply soon, because I think either the documentation is not mentionning an important aspect for producing valid png or jpg, or something is odd. But at the same time, I could not even find a working project online that would actual render an image on my m5dial...
          felmue @greenleaf
          Hello @greenleaf
          in order for the image to show on the actual device it needs to be manually downloaded to the device into the correct path, e.g. res/img.
          J greenleafG 2 Replies Last reply Reply Quote 0
            jeanfabre @felmue
              greenleaf @felmue
              @felmue ok, then UIFlow 2 has a bug in it, it seems. I used the UI to upload and select the image. If it's being put in the wrong folder that is confusing for users.
                felmue @greenleaf
                Hello @greenleaf
                I would agree, by default images (actually any files for that matter) are uploaded into the root folder whereas the image is expected to be in res/img which only becomes obvious when looking at the Micropython source code.
                  greenleaf @felmue
                  Ok I took a closer look - the files don't even make it onto the device at all.
                  Is this perhaps an unfinished feature? I would expect that when I upload files into a "project" that they end up on the device somewhere. I don't see a way in the UI to move files from the project to the device, so I have to upload them all again.
                  Is this by design? Or did I run into a missing feature or bug...projectfiles.png devicefiles.png
                    @greenleaf
                    Ok, I found a workaround. Here it is in case anyone else runs into this:
                    1. Use the WebTerminal File button to upload your images into /flash/res/img
                    2. Edit the paths to any of your images in code to /flash/res/img/yourfile.jpg
                      @greenleaf Final update, it appears that if you upload the images both to the project and onto the device directly, that you can use the UIflow way to place them and resize them, etc.
                      I did find some weirdness with older versions of images being cached on the UI, but correct on the device.
                      • lbuqueL Offline
                        lbuque
                        https://uiflow-micropython.readthedocs.io/en/latest/quick-reference/usb-mode.html
