    M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.
    12 Posts 5 Posters 6.2k Views
      PhilB79
      New user, and quite old< trying to make use of UIflow2. Arduino is good but not micropython
      robskiR teastainT ajb2k3A P 4 Replies Last reply Reply Quote 0
      • robskiR Offline
        robski @PhilB79
        @PhilB79 did you tried to update its firmware to latest via m5burner?
        • teastainT Offline
          teastain @PhilB79
          @PhilB79 Can you upload a small Arduino IDE test file?
          Like a generic serial monitor test?
            ajb2k3 @PhilB79
            @PhilB79 What's reporting the error?
              PhilB79 @PhilB79
              @PhilB79
              Yes to the latest version more the once
                PhilB79 @teastain
                @teastain
                UIflow 2 / Select device / RED dot next to the CoreS3 graphic. Same applies to CoreS3
                  PhilB79 @robski
                  @robski
                  Can do but not until later today
                  • robskiR Offline
                    robski @PhilB79
                    @PhilB79 you have to use M5Burner when loogged in so firmware update "binds" your device in to your uiflow account and then it is visible on the list if connected to internet.
                      PhilB79 @robski
                      @robski said in M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.:
                      Yes I use the full process of Erase, Bind and Burn. Tried many time but still the Red dot in device select.
                      I'm about to give up and put the lot in the bin and go back to ESP32s
                      felmueF robskiR 2 Replies Last reply Reply Quote 0
                      • felmueF Online
                        felmue @PhilB79
                        Hello @PhilB79
                        before you give up.
                        For the dot to turn green of any M5Core in the My Device list the M5Core needs to have a wireless connection and an established connection to the UIFlow2 cloud server.
                        On the initial UIFlow2 screen on the M5Core there are two symbols, one for wireless and one for the cloud server, in the top right corner (next to the battery symbol).
                        • the wireless symbol needs to be not crossed out.
                        • the cloud server symbol needs to be without question mark.
                        Below are the steps these two icons go through after boot up / reset of the M5Core:
                        UIFlow2_WirelessNOK_CloudNOK_20241018.png Wireless not ok - Cloud not ok
                        UIFlow2_WirelessOK_CloudNOK_20241018.png Wireless ok - Cloud not ok
                        UIFlow2_WirelessOK_CloudOK_20241018.png Wireless ok - Cloud ok
                        • robskiR Offline
                          robski @PhilB79
                          @PhilB79 so after such process is your device showing connected to uiflow cloud? is it showing your email address (all should be visible on device startup page)
                          • robskiR Offline
                            robski @PhilB79
                            @PhilB79 said in M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.:
                            @teastain
                            silly question but you are logged in to Uiflow2 with same login credentials as in M5Burner (bind)
