    Ext encoder button
    Units
    2.1k
    • L
      louisandthecat
      Hi all
      I’ve successfully got a KY040 rotary encoder working with the m5Stack ext- encoder unit.
      I can register rotations but the part I haven’t made work is the push button - which is a straightforward contact button
      There is an input for it on the ext encoder marked as Z but I can’t find any documentation on how I read this button and there seem to be no functions in the class to handle it.
      Does anyone have any idea how I handle this?
      Thanks in advance
      • teastainT
        teastain @louisandthecat
        @louisandthecat
        In robotics and CNC the Z input is the third phase of the encoder usually to tell the controller that you have gone around once.
        You have a KeyStudio encoder with only two phases and the third is the press to click.
        The library reads this as:
        #define UNIT_EXT_ENCODER_ZERO_PULSE_VALUE_REG 0x60
        #define UNIT_EXT_ENCODER_ZERO_MODE_REG 0x70
        Pushing it should Zero out the counts.
        What controller are you using?
        And what IDE are you programming in?
        L 1 Reply Last reply Reply Quote 1
        • L
          louisandthecat @teastain
          @teastain Thank you - I had misunderstood what the Z was for. Because on the ky040 the middle pin is for the "switch" functionality (i.e. pushing down on the encoder) I assumed it was for this. I realise now that I need to treat that as a button and take it off to a different pin, which I know how to do.
          Thanks for your help!
