Ext encoder button
 Hi all I’ve successfully got a KY040 rotary encoder working with the m5Stack ext- encoder unit. I can register rotations but the part I haven’t made work is the push button - which is a straightforward contact button There is an input for it on the ext encoder marked as Z but I can’t find any documentation on how I read this button and there seem to be no functions in the class to handle it. Does anyone have any idea how I handle this? Thanks in advance
 @louisandthecat
 In robotics and CNC the Z input is the third phase of the encoder usually to tell the controller that you have gone around once.
 You have a KeyStudio encoder with only two phases and the third is the press to click.
 The library reads this as:
 #define UNIT_EXT_ENCODER_ZERO_PULSE_VALUE_REG 0x60
 #define UNIT_EXT_ENCODER_ZERO_MODE_REG 0x70
 Pushing it should Zero out the counts.
 What controller are you using?
 And what IDE are you programming in?
 @teastain Thank you - I had misunderstood what the Z was for. Because on the ky040 the middle pin is for the "switch" functionality (i.e. pushing down on the encoder) I assumed it was for this. I realise now that I need to treat that as a button and take it off to a different pin, which I know how to do. Thanks for your help!
