    Tab5 RS485 connector
    PRODUCTS
    5
    140
    • C
      clydeps
      The Tab5 has a 6 way connector that includes the RS485 signals, but none of the cables I have fit it - it's quite a fine pitch. The docs don't mention it. What is the type of connector?
      TIA, Clyde
        felmue @clydeps
        Hello @clydeps
        I don't know the pitch of the connector. However my M5Tab5 came with a matching cable. Maybe double-check your box?
        • C
          clydeps
          Yeah, thanks - I dug through my waste basket and found the box it came in - the cable was hidden inside the packaging. I believe it's 1.25 pitch.
          • robskiR
            robski
            cable is well hidden in Tab5 box, good to know you found it
              scroggyg
              I do think it is too fragile to be of any practical use, I am trying to surface mount a TAB5 in a 3D printed bezel but as all the other connections are on the side, it isn't easy
