    Using WiFi on Tab5 with the Arduino IDE
    17 Posts 7 Posters 12.1k Views 2 Watching
      smily77
      This applies as well if you use the M5Stack pkg? - is there a "how to" somewere for this?
        felmue @smily77
        Hello @smily77
        no, AFAIK there is no specific 'how to' for M5Tab5 - only the generic about how to build your own Arduino library using Arduino library builder or how to use Arduino as ESP-IDF component. See links above.
          smily77
          There seams to be an additional Issue the Tab5 uses SDIO2 - The correct GPIO's only don't work
            felmue @smily77
            Hello @smily77
            I believe SDIO2 is used so the communication between ESP32P4 (master) and ESP32C6 (slave) can be exclusive, e.g. not shared with other slaves.
            • N Offline
              New_Comix
              Hi there,
              are there any (better) news about using Wifi within the Arduino environment?
              kind regards
              Jörg
                felmue @New_Comix
                Hi guys
                corresponding github issue for reference.
                It seems there isn't an easier way just (yet) than using Espressif Library Builder.
                  smily77 @felmue
                  It was mentioned that in the next ESP-Arduino package 3.3.0 the issue with the connection will be solved by this possibility:
                  WiFi.setPins(clk, cmd, d0, d1, d2, d3, rst);
                  WiFi.begin(ssid, pass);
                  This sounds promising. However the Tab 5 doc's lists the Pins for clk, cmd, d0, d1, d2, d3 but not for the reset pin (rst). Does somebody know how the reset of the C6 is wired to the P4 in the Tab 5?
                  felmueF S 2 Replies Last reply Reply Quote 0
                    felmue @smily77
                    Hello @smily77
                    according to the schematic GPIO15 is used as reset pin (SOC_EXTRF_RST).
                      sapphire @smily77
                      @smily77 Did you manage to get the SD card reader to work?
                        Krmiller @sapphire
                        @sapphire Same, can't get the SD to work. Anyone?
                        Thanks,
                        Kris
                          sapphire
                          I managed to get the SD card reader to work.
                          H_SDIO_DRV error: sdio card init failed
                          The WiFi module (ESP32-C6) uses an independent set of dedicated pins (SDIO2_D0 to SDIO2_CK), thus avoiding any physical interface overlap and conflicts.
                          sd_mmc_card:
                          clk_pin: GPIO43
                          cmd_pin: GPIO44
                          data0_pin: GPIO39
                          data1_pin: GPIO40
                          data2_pin: GPIO41
                          data3_pin: GPIO42
                          mode_1bit: false
                          slot: 0
                          esp32_hosted:
                          variant: esp32c6
                          active_high: true
                          clk_pin: GPIO12
                          cmd_pin: GPIO13
                          d0_pin: GPIO11
                          d1_pin: GPIO10
                          d2_pin: GPIO9
                          d3_pin: GPIO8
                          reset_pin: GPIO15
                          slot: 1
                            jredrejo @sapphire
                            @sapphire but this topic refers to WiFi. any one could solve this probem? I've tried all the steps I've could without success.
                            It seems there are more people who are having this same issue, no way to use wifi in our Tab5: https://www.reddit.com/r/M5Stack/comments/1p04d3b/comment/ntozc4p/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
