    Using WiFi on Tab5 with the Arduino IDE
    17 Posts 7 Posters 11.2k Views 2 Watching
      smily77
      I got my Tab5 - cool thing :-) but I I have an issue with WiFi.
      Basically the C6 should work as a coprocessor connected with SIDO. This should allow using Wifi as normal with:
      #include <WiFi.h>
      WiFi.begin(ssid, password);
      in the Arduino IDE. But instead a runtime error appears, and it restarts amd so on
               sdio_mempool_create free:34078468 min-free:34077500 lfb-def:33030132 lfb-8bit:33030132
              E (1734) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
              E (1734) sdio_wrapper: sdmmc_card_init failed
              E (4372) H_SDIO_DRV: sdio card init failed
             FreeRTOS: FreeRTOS Task "sdio_read" should not return, Aborting now!
      Does anyone know how to fix or have just a working example (there isn't any example around and even the P4 example with WiFi in the arduino IDE do not work)
      Arduino IDE : 2.3.6; M5Stack Package 3.2.0 (all M5Stack lib on the latest state as well)
      • teastainT Offline
        teastain @smily77
        @smily77 said in Using WiFi on Tab5 with the Arduino IDE:
        This board pkg (3.20) seems to be broken for many of us.
        We have had to revert to ver2.14 and I have notified M5Stack support.
        Try reverting and see.
        If still a problem make a simpler de-bug version of your sketch and add complications.
          smily77 @teastain
          @teastain thanks but unfortunatly doesn't the Tab5 exist in 2.1.4 an simpler than the below can't the sketch be made:
          #include <M5Unified.h>
          #include <WiFi.h>
          auto cfg = M5.config();
          M5.begin(cfg); // ← hier wird intern der C6 hochgefahren
          teastainT 1 Reply Last reply Reply Quote 2
          • teastainT Offline
            teastain @smily77
            @smily77 a-HA!
            Thank you.
              felmue @teastain
              Hi guys
              the ESP32C6 is connected via SDIO bus to the ESP32P4 but unfortunately the GPIOs used in Tab5 differ from the GPIOs used by the ESP32P4 eval board.
              In other words the pre-compiled Arduino library is setup to use SDIO GPIOs which do not match the Tab5 hardware.
              So in order to use Arduino you'll need to pre-compile the Arduino library yourself using the Arduino library builder or setup the build system to use Arduino as ESP-IDF component. Both ways should allow to modify the SDIO GPIOs accordingly.
              Note: the SDIO GPIOs used in Tab5 can be found here.
                smily77
                This applies as well if you use the M5Stack pkg? - is there a "how to" somewere for this?
                  felmue @smily77
                  Hello @smily77
                  no, AFAIK there is no specific 'how to' for M5Tab5 - only the generic about how to build your own Arduino library using Arduino library builder or how to use Arduino as ESP-IDF component. See links above.
                    smily77
                    There seams to be an additional Issue the Tab5 uses SDIO2 - The correct GPIO's only don't work
                      felmue @smily77
                      Hello @smily77
                      I believe SDIO2 is used so the communication between ESP32P4 (master) and ESP32C6 (slave) can be exclusive, e.g. not shared with other slaves.
                      • N Offline
                        New_Comix
                        Hi there,
                        are there any (better) news about using Wifi within the Arduino environment?
                        kind regards
                        Jörg
                          felmue @New_Comix
                          Hi guys
                          corresponding github issue for reference.
                          It seems there isn't an easier way just (yet) than using Espressif Library Builder.
                            smily77 @felmue
                            It was mentioned that in the next ESP-Arduino package 3.3.0 the issue with the connection will be solved by this possibility:
                            WiFi.setPins(clk, cmd, d0, d1, d2, d3, rst);
                            WiFi.begin(ssid, pass);
                            This sounds promising. However the Tab 5 doc's lists the Pins for clk, cmd, d0, d1, d2, d3 but not for the reset pin (rst). Does somebody know how the reset of the C6 is wired to the P4 in the Tab 5?
                            felmueF S 2 Replies Last reply Reply Quote 0
                              felmue @smily77
                              Hello @smily77
                              according to the schematic GPIO15 is used as reset pin (SOC_EXTRF_RST).
                                sapphire @smily77
                                @smily77 Did you manage to get the SD card reader to work?
                                  Krmiller @sapphire
                                  @sapphire Same, can't get the SD to work. Anyone?
                                  Thanks,
                                  Kris
                                    sapphire
                                    I managed to get the SD card reader to work.
                                    H_SDIO_DRV error: sdio card init failed
                                    The WiFi module (ESP32-C6) uses an independent set of dedicated pins (SDIO2_D0 to SDIO2_CK), thus avoiding any physical interface overlap and conflicts.
                                    sd_mmc_card:
                                    clk_pin: GPIO43
                                    cmd_pin: GPIO44
                                    data0_pin: GPIO39
                                    data1_pin: GPIO40
                                    data2_pin: GPIO41
                                    data3_pin: GPIO42
                                    mode_1bit: false
                                    slot: 0
                                    esp32_hosted:
                                    variant: esp32c6
                                    active_high: true
                                    clk_pin: GPIO12
                                    cmd_pin: GPIO13
                                    d0_pin: GPIO11
                                    d1_pin: GPIO10
                                    d2_pin: GPIO9
                                    d3_pin: GPIO8
                                    reset_pin: GPIO15
                                    slot: 1
                                      jredrejo @sapphire
                                      @sapphire but this topic refers to WiFi. any one could solve this probem? I've tried all the steps I've could without success.
                                      It seems there are more people who are having this same issue, no way to use wifi in our Tab5: https://www.reddit.com/r/M5Stack/comments/1p04d3b/comment/ntozc4p/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
