    Using WiFi on Tab5 with the Arduino IDE
    17 Posts 7 Posters 12.1k Views 2 Watching
    • teastainT Offline
      teastain @smily77
      @smily77 said in Using WiFi on Tab5 with the Arduino IDE:
      M5Stack Package 3.2.0
      This board pkg (3.20) seems to be broken for many of us.
      We have had to revert to ver2.14 and I have notified M5Stack support.
      Try reverting and see.
      If still a problem make a simpler de-bug version of your sketch and add complications.
        smily77 @teastain
        @teastain thanks but unfortunatly doesn't the Tab5 exist in 2.1.4 an simpler than the below can't the sketch be made:
        #include <M5Unified.h>
        #include <WiFi.h>
        auto cfg = M5.config();
        M5.begin(cfg); // ← hier wird intern der C6 hochgefahren
        WiFi.begin(ssid, password);
        teastainT 1 Reply Last reply Reply Quote 2
        • teastainT Offline
          teastain @smily77
          @smily77 a-HA!
          Thank you.
            felmue @teastain
            Hi guys
            the ESP32C6 is connected via SDIO bus to the ESP32P4 but unfortunately the GPIOs used in Tab5 differ from the GPIOs used by the ESP32P4 eval board.
            In other words the pre-compiled Arduino library is setup to use SDIO GPIOs which do not match the Tab5 hardware.
            So in order to use Arduino you'll need to pre-compile the Arduino library yourself using the Arduino library builder or setup the build system to use Arduino as ESP-IDF component. Both ways should allow to modify the SDIO GPIOs accordingly.
            Note: the SDIO GPIOs used in Tab5 can be found here.
              smily77
              This applies as well if you use the M5Stack pkg? - is there a "how to" somewere for this?
                felmue @smily77
                Hello @smily77
                no, AFAIK there is no specific 'how to' for M5Tab5 - only the generic about how to build your own Arduino library using Arduino library builder or how to use Arduino as ESP-IDF component. See links above.
                  smily77
                  There seams to be an additional Issue the Tab5 uses SDIO2 - The correct GPIO's only don't work
                    felmue @smily77
                    Hello @smily77
                    I believe SDIO2 is used so the communication between ESP32P4 (master) and ESP32C6 (slave) can be exclusive, e.g. not shared with other slaves.
                    • N Offline
                      New_Comix
                      Hi there,
                      are there any (better) news about using Wifi within the Arduino environment?
                      kind regards
                      Jörg
                        felmue @New_Comix
                        Hi guys
                        corresponding github issue for reference.
                        It seems there isn't an easier way just (yet) than using Espressif Library Builder.
                          smily77 @felmue
                          It was mentioned that in the next ESP-Arduino package 3.3.0 the issue with the connection will be solved by this possibility:
                          WiFi.setPins(clk, cmd, d0, d1, d2, d3, rst);
                          WiFi.begin(ssid, pass);
                          This sounds promising. However the Tab 5 doc's lists the Pins for clk, cmd, d0, d1, d2, d3 but not for the reset pin (rst). Does somebody know how the reset of the C6 is wired to the P4 in the Tab 5?
                          felmueF S 2 Replies Last reply Reply Quote 0
                            felmue @smily77
                            Hello @smily77
                            according to the schematic GPIO15 is used as reset pin (SOC_EXTRF_RST).
                              sapphire @smily77
                              @smily77 Did you manage to get the SD card reader to work?
                                Krmiller @sapphire
                                @sapphire Same, can't get the SD to work. Anyone?
                                Thanks,
                                Kris
                                  sapphire
                                  I managed to get the SD card reader to work.
                                  H_SDIO_DRV error: sdio card init failed
                                  The WiFi module (ESP32-C6) uses an independent set of dedicated pins (SDIO2_D0 to SDIO2_CK), thus avoiding any physical interface overlap and conflicts.
                                  sd_mmc_card:
                                  clk_pin: GPIO43
                                  cmd_pin: GPIO44
                                  data0_pin: GPIO39
                                  data1_pin: GPIO40
                                  data2_pin: GPIO41
                                  data3_pin: GPIO42
                                  mode_1bit: false
                                  slot: 0
                                  esp32_hosted:
                                  variant: esp32c6
                                  active_high: true
                                  clk_pin: GPIO12
                                  cmd_pin: GPIO13
                                  d0_pin: GPIO11
                                  d1_pin: GPIO10
                                  d2_pin: GPIO9
                                  d3_pin: GPIO8
                                  reset_pin: GPIO15
                                  slot: 1
                                    jredrejo @sapphire
                                    @sapphire but this topic refers to WiFi. any one could solve this probem? I've tried all the steps I've could without success.
                                    It seems there are more people who are having this same issue, no way to use wifi in our Tab5: https://www.reddit.com/r/M5Stack/comments/1p04d3b/comment/ntozc4p/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
