    M5StickC screen don't work
    25 Posts 11 Posters 109.0k Views 4 Watching
      davidtgbe @davidtgbe
      Ok, I've solved it with this sequence.
      1. Erase and then flash UIFlow with M5Burner.
      2. Disconnect USB from PC
      3. Press PWR Button 6 sec to turn stick off.
      4. Connect M5Stick to PC again
      • liemphL Offline
        liemph @HunterDAce
        @hunterdace I had the same experience several times when I connected the M5StickC with the servo drive unit. However, I managed to resolve the problem by uploading the factor test sample code. I don't know the root problem but it helped. The only thing I suspected (but hopefully not) is that the problem appeared AFTER I updated my Ardunio IDE from 1.8.9 to 1.8.10. However, this may be a coincidence only.
          ForestRupicolous
          Hello together,
          I had an Issue with the screen together with micropython (see http://community.m5stack.com/topic/1578/micropython-port-form-m5stickc) and it is possible that for the same reason your sw isn't working. The M5MicroC uses the AXP192 PMIC (this picture is really good: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp) to control all the energy related stuff. As far as I've seen the documents it was introduced in the orange version and is not part of the bigger M5Core (at least not for the version I saw the code). Therefore a lot of libraries don't enable the LDO for the display and background led which led to my issues. In the code you are referencing I'm also not seeing any AXP192 files.
          • N Offline
            nsfilho @davidtgbe
            @davidtgbe Did you found any solution? Because I have the same problem. My M5Stick-C is fully functional, except by screen (which is totally black).
            I tried the Factory Test Firmware, put my own firmware and nothing. I tried to short-cut pins BAT+GND, and insert the USB-C cable, but the screen does not lit (I waited for 2 secs), after that, I removed the short-cut (I'm afraid about fry my device).
            How much time are you waited in this short-cut? Anyone can help us??
            EDIT: in my firmware I used the default settings as bellow
            void setup(void)
                M5.begin(true, true, true);
                M5.Lcd.fillScreen(WHITE);
                M5.Axp.ScreenBreath(15); // 7-15
            Anyways, the screen isn't show anything including in the Factory Test Firmware. When I try to used UIFlow, show me an error when connect via I2C to AXP. Are anyone experienced something like that?
            @m5stack can you help me, please?
            EDIT2: More information when I run UIFlow (terminal info):
            --- Miniterm on /dev/cu.usbserial-3D527252B4  115200,8,N,1 ---
            --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
            ␛[0;32mI (9) boot: ESP-IDF v3.3-beta1-696-gc4c54ce07 2nd stage bootloader␛[0m
            ␛[0;32mI (9) boot: compile time 19:32:01␛[0m
            ␛[0;32mI (9) boot: Enabling RNG early entropy source...␛[0m
            ␛[0;32mI (14) boot: SPI Speed      : 80MHz␛[0m
            ␛[0;32mI (18) boot: SPI Mode       : DIO␛[0m
            ␛[0;32mI (22) boot: SPI Flash Size : 4MB␛[0m
            ␛[0;32mI (26) boot: Partition Table:␛[0m
            ␛[0;32mI (29) boot: ## Label            Usage          Type ST Offset   Length␛[0m
            ␛[0;32mI (37) boot:  0 nvs              WiFi data        01 02 00009000 00006000␛[0m
            ␛[0;32mI (44) boot:  1 phy_init         RF data          01 01 0000f000 00001000␛[0m
            ␛[0;32mI (52) boot:  2 factory          factory app      00 00 00010000 001f0000␛[0m
            ␛[0;32mI (59) boot:  3 internalfs       Unknown data     01 81 00200000 00200000␛[0m
            ␛[0;32mI (67) boot: End of partition table␛[0m
            ␛[0;32mI (71) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0xe95ac (955820) map␛[0m
            ␛[0;32mI (354) esp_image: segment 1: paddr=0x000f95d4 vaddr=0x3ffbdb60 size=0x034dc ( 13532) load␛[0m
            ␛[0;32mI (359) esp_image: segment 2: paddr=0x000fcab8 vaddr=0x40080000 size=0x00400 (  1024) load␛[0m
            ␛[0;32mI (361) esp_image: segment 3: paddr=0x000fcec0 vaddr=0x40080400 size=0x03150 ( 12624) load␛[0m
            ␛[0;32mI (374) esp_image: segment 4: paddr=0x00100018 vaddr=0x400d0018 size=0xdcac4 (903876) map␛[0m
            ␛[0;32mI (638) esp_image: segment 5: paddr=0x001dcae4 vaddr=0x40083550 size=0x12a98 ( 76440) load␛[0m
            ␛[0;32mI (664) esp_image: segment 6: paddr=0x001ef584 vaddr=0x400c0000 size=0x00064 (   100) load␛[0m
            ␛[0;32mI (664) esp_image: segment 7: paddr=0x001ef5f0 vaddr=0x50000000 size=0x00808 (  2056) load␛[0m
            ␛[0;32mI (685) boot: Loaded app from partition at offset 0x10000␛[0m
            ␛[0;32mI (685) boot: Disabling RNG early entropy source...␛[0m
            ␛[0;32mI (685) cpu_start: Pro cpu up.␛[0m
            ␛[0;32mI (689) cpu_start: Application information:␛[0m
            ␛[0;32mI (694) cpu_start: Compile time:     Dec 27 2019 19:32:08␛[0m
            ␛[0;32mI (700) cpu_start: ELF file SHA256:  0000000000000000...␛[0m
            ␛[0;32mI (706) cpu_start: ESP-IDF:          v3.3-beta1-696-gc4c54ce07␛[0m
            ␛[0;32mI (712) cpu_start: Starting app cpu, entry point is 0x400836e4␛[0m
            ␛[0;32mI (0) cpu_start: App cpu up.␛[0m
            ␛[0;32mI (723) heap_init: Initializing. RAM available for dynamic allocation:␛[0m
            ␛[0;32mI (730) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM␛[0m
            ␛[0;32mI (736) heap_init: At 3FFCB2D8 len 00014D28 (83 KiB): DRAM␛[0m
            ␛[0;32mI (742) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM␛[0m
            ␛[0;32mI (748) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM␛[0m
            ␛[0;32mI (755) heap_init: At 40095FE8 len 0000A018 (40 KiB): IRAM␛[0m
            ␛[0;32mI (761) cpu_start: Pro cpu start user code␛[0m
            ␛[0;32mI (107) cpu_start: Starting scheduler on PRO CPU.␛[0m
            ␛[0;32mI (0) cpu_start: Starting scheduler on APP CPU.␛[0m
            Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2097152; Flash address: 0x200000]
            Filesystem size: 2035712 B
                       Used: 479232 B
                       Free: 1556480 B
              File "boot.py", line 4, in <module>
              File "flowlib/uiflow.py", line 1, in <module>
              File "flowlib/m5stack.py", line 14, in <module>
              File "flowlib/hw/axp192.py", line 28, in powerAll
              File "flowlib/hw/axp192.py", line 125, in _regChar
            OSError: I2C bus error (-1)
              File "main.py", line 1, in <module>
            NameError: name 'lcd' isn't defined
            MicroPython v1.11-316-gca0d8a0a5 on 2019-12-27; ESP32 module with ESP32
              ForestRupicolous
              Is see two possible issues:
              The AXP192 PMIC is controlled via I2C, if the bus isn't working maybe the LDO3/2 isn't enabled. Start with a I2C scan to see if a device with address 52 (thats the AXP192) is available. More code is in the post linked above.
              Something went wrong with the initialization of the lcd python module. Maybe the wrong version is included?
              • N Offline
                nsfilho @ForestRupicolous
                @forestrupicolous first of all, thank you by your support. No I2C devices was found.
                M5StickC initializing...OK
                M5StickC I2C Tester
                Millis: 4041 - Scanning Address
                Finished, total: 0 devices!
                I made the code bellow to scan:
                #include <M5StickC.h>
                void setup()
                  Serial.println("M5StickC I2C Tester");
                  Wire.begin();
                  delay(3000);
                void loop()
                  byte address, error;
                  byte devices = 0;
                  Serial.print("Millis: ");
                  Serial.print(millis());
                  Serial.println(" - Scanning Address");
                  for(address = 1; address < 127; address++ )
                    if (error==0)
                      devices++;
                      Serial.print("- Found: 0x");
                      Serial.println(address, HEX);
                    delay(10);
                  Serial.print("Finished, total: ");
                  Serial.print(devices);
                  Serial.println(" devices!\n\n");
                  delay(5000);
                What you believe I need to do? Because my hardware are entirely new and I don't used any pins for nothing.
                I bought more U$ 400.00 in hardware from M5Stack and I'm very preocupated if something like that happens to others. Because the logistic process to repair could be inviable (country rules: Brazil).
                If you have any insight to solve that, I'll be appreciate. Thank you in advance.
                @m5stack please, help me!!
                • N Offline
                  nsfilho @nsfilho
                  Today has arrived more two M5Stick-C units for me. After some tests, I discovered more I2C Channels to test. In a fully functional M5Stick-C Unit, I have this result:
                  M5StickC I2C Tester
                  Millis: 4057 - Scanning Address
                  Port: 1 - Found: 0x34
                  Port: 1 - Found: 0x51
                  Port: 1 - Found: 0x68
                  Finished, total: 3 devices!
                  When I run the same software in a unit with problem, I obtain the bellow result:
                  M5StickC I2C Tester
                  Millis: 4047 - Scanning Address
                  Finished, total: 2 devices!
                  The AXP I2C address (0x34) is not found. Are anyone knows how to solve that?
                  @m5stack please help me.
                  @lukasmaximus I see you have a big knowloged about M5Stack products. Are you know something about that? Could you help me, please?
                  My I2C tester code:
                  void setup()
                    Wire.begin();
                    Wire1.begin();
                    delay(3000);
                  byte checkResult(byte error, byte address, byte wirePort)
                    if (error == 0)
                      Serial.print("Port: ");
                      Serial.print(wirePort);
                      Serial.print(" - Found: 0x");
                      return 1;
                    return 0;
                  void loop()
                    byte address = 1;
                    byte devices = 0;
                    for (; address < 127; address++)
                      Wire1.beginTransmission(address);
                      devices += checkResult(Wire.endTransmission(), address, 0);
                      devices += checkResult(Wire1.endTransmission(), address, 1);
                      delay(10);
                    delay(5000);
                    clive.dent
                    Hi. I just want to say that I was able to solve this strange issue with the BAT - GND cable trick. It didn't work at first and I was getting only two ports from nsfilho's script. But then I figured it out. I just had to turn the device off by holding the power button for 6s first and then the cable trick worked.
                    • N Offline
                      nsfilho @clive.dent
                      @clive-dent How much time have you waited with a jumper between GND and BAT? I'm asking that, because I'm a little afraid about to jumper GND and BAT, specially because it is a LIPO Battery (can explode).
                      But if it is a solution, I'll do that! If you can tell me the how much time, I really appreciate. Please, let me ask you something, If you could create a Youtube video showing that solution, I belive it will be amazing. Many M5Stick-C buyers will go to face this same problem and now have no reference to follow.
                      Thank you again by your disposition to share how to solve the problem :)
                      • mdevel1M Offline
                        mdevel1
                        I had the same issue with one of my two sticks, which appeared and disappeared without (intentionally) shorting anything and found two loose magnets inside. See the Loose magnets inside can short the battery and other components topic for more details. The magnets might have shorted some pins while I was trying to remove them (or caused the whole issue beforehand).
                        While my stick was defective I had access to the AXP on the I2C bus (I think the M5.Axp.GetBatState() or any other Axp call would not work otherwise), but the returned values were incomprehensible. Since my stick is working now, can you test the code posted there to dump the data form the AXP chip?
                        • N Offline
                          nsfilho @mdevel1
                          @mdevel1 After your message, I opened my M5Stick-C too, but in my case, the magnets is in a properly slots. I didn't found any problems after a quick look in the board and components.
                          If anyone have any idea about how to procedure, I'll appreciate!
                          Thank you in advance and thank you for share with us.
                          mdevel1M 1 Reply Last reply Reply Quote 0
                          • mdevel1M Offline
                            mdevel1 @nsfilho
                            @nsfilho Have you tried to upload my AXP data query code? I added the possibility to dump the results to USB as well as an external serial port, so no other device is needed for running it.
                            • N Offline
                              nsfilho @mdevel1
                              @mdevel1 the problem is AXP Address 0x34 is not responding. Because of that, M5.Axp interface can't connect (and can't power-up screen).
                              M5.Axp use Wire1 as I2C to communicate on ports 21 and 22, as described in https://github.com/m5stack/M5StickC/blob/master/src/AXP192.cpp.
                              Because of that, any commands as Wire1.beginTransmission, result in error. The M5.Axp, use Write1Byte to send information (and is not validating if was successful, because of that, I haven't any log).
                              void AXP192::Write1Byte( uint8_t Addr ,  uint8_t Data )
                                  Wire1.beginTransmission(0x34);
                                  Wire1.write(Addr);
                                  Wire1.write(Data);
                                  Wire1.endTransmission();
                              The I2C Axp Address (0x34) isn't ready in one of my M5Stick-C. If you have any idea, please let me know -- I'm really trying anything to get AXP fully functional again, because I can't see anything (in display) without Axp.
                              In my code above, you will see a test in endTransmission as mencioned to test the result.
                              Thank you by all your attention. Please let me know if you have any idea.
                              • mdevel1M Offline
                                mdevel1 @nsfilho
                                @nsfilho
                                I'm sorry, I did not know that the code fails earlier, I just had to exclude the possibility that it can fail in a way which results the strange output from the AXP chip I was seeing when my screen was not working. This also means that my problem was different.
                                In this case I don't have any more ideas, except taking apart the stick completely very carefully (see the photos how it can break, and then desolder the LiPo battery (or just cut the cables separately, very close to the PCB). I don't know if your stick has the button battery (mine does not), and what is it connected to, but it's possible that it must be disconnected somehow too. When you don't have any batteries or power sources connected, you might try to discharge any capacitors nearby, which should definitely put the AXP chip in a known stable state without the risk of shorting and damaging any battery. I would then inspect the AXP chip, the PCB traces and the components nearby for shorts, cuts, corrosion or any anomaly. If nothing found, then try to power from USB (preferably with a current meter) and see what happens.
                                I'm not aware of others having the exact same problem, so yours might be unique.
                                  clive.dent @nsfilho
                                  @nsfilho Not very long, 3s max. I didn't know that, thanks for warning! The problem keeps reappearing so I will keep that in mind.
                                  • I Offline
                                    ilex73 @HunterDAce
