    Connecting M5Stack to an MQ-2 smoke/gas sensor
    FAQS
    21.7k
      Suntzu
      I am trying to port my ESP8266 project to M5Stack but for the life of me I could not figure out how to connect the wires between M5Stack and the analog MQ-2 gas sensor.
      This is my wiring for ESP8266 that perfectly works:
       MQ-2 Sensor    ->    ESP8266
           A0         ->      A0
           D0         ->      D0
           VCC        ->      VIN (5.5V)
           GRD        ->      GRD
      This is what I have tried in M5Stack but did not work. The sensor's D0 LED and power LED do not even lit on.
       MQ-2 Sensor    ->      M5Stack
           A0         ->        Pin 36 (I also have tried 35)
           D0         ->        Pin 21 (I also have tried 16)
           VCC        ->        5V
           GRD        ->        G
      How do I wire the analog MQ-2 sensor To M5Stack? Is it doable? Any guidance please?
      • JJJ
        JJ @Suntzu
        @suntzu Hi Suntu,
        Try sourcing the 5V from the positive terminal on the Grove connector.
          Suntzu
          @JimiT I will try that when I get back home from the office. And I will make sure to keep you updated.
          Thank you so much, Jimi.
            Suntzu @JJ
            @jimit 在 Connecting M5Stack to an MQ-2 smoke/gas sensor 中说:
            @suntzu Hi Suntu,
            It worked like a charm! Thank you again. It's time to rewrite my sketches for M5Stack.
            • JJJ
              JJ @Suntzu
              @suntzu Glad to hear it worked !!!!
              And you used pins 36 and 21 ?
              Now I will have to order some of these MQ-2 sensors !! Thank you for the tip.
              If you are open to posting a link to your code or a screenshot when done, that would be interesting to see.
                Suntzu
                @JimiT Yes, I used Pin 36 and 21.
                Absolutely, I will post the finish product and pictures in the Projects section.
                • D
                  DrWino
                  I am been able to read the ADC on pin 35. This corresponds to ADC1_CH7 BUT I cannot get ADC on pin 36 to work. I think this is ADC1-CH0. Anybody has any sample code ? Thanks.
