    Speaker beep and Wait
    UIFlow
    22
    57.6k
    • M5StickFreaklerM
      M5StickFreakler
      Hi folks
      If I use a "speaker beep" and "wait" in uiflow, all my m5stack cores hangs up after 3-8 beeps.
      Is it wrongly implemented in uiflow?
      best regards
      Thomas
      • world101W
        world101 @M5StickFreakler
        @m5stickfreakler
        Post your flow or code and someone might be able to help.
        • M5StickFreaklerM
          M5StickFreakler
          @m5stickfreakler said in Speaker beep and Wait:
          best regards
          simple example
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import unit
          tof0 = unit.get(unit.TOF, unit.PORTA)
          @timerSch.event('timer1')
          def ttimer1():
          global unit
          wait(1)
          speaker.sing(831, 1/16)
          pass
          timerSch.run('timer1', 1000, 0x00)
          • M5StickFreaklerM
            M5StickFreakler
            This Code generates no sound or an endless sound but not the expected 1/16 beep each second
            m5stackM world101W 2 Replies Last reply Reply Quote 0
            • m5stackM
              m5stack @M5StickFreakler
              @m5stickfreakler if you just want control it play 1/16 beep each second , why you use interrupt and wait at the same time? you can just use a loop block. then put the wait and beep program inside.
              • M5StickFreaklerM
                M5StickFreakler
                Its just an example to demonstrate the bug. The use case is much more complicate.
                • m5stackM
                  @m5stickfreakler try to delete the wait block in the callback program.
                  • M5StickFreaklerM
                    M5StickFreakler
                    Of course it is the same behavior.
                    Try it out yourself!
                    Run the program and wait for some beeps and you will hear a continues tone.
                    Its obviously a bug.
                    • M5StickFreaklerM
                      M5StickFreakler
                      Same problem occurs with LED and with 3 different M5Stack units.
                      Try it out and you will see that after some blinking phase it will stuck up in a permanent light.
                      I think that is a big problem...
                      • sysdl132S
                        sysdl132
                        Hi.That is unusual...Try to upload it on a different device(if you have)and check.
                        For Atom:115200/230400/921600
                        • M5StickFreaklerM
                          M5StickFreakler
                          Thank you for reply
                          I told you I have uploaded it to 3 different devices. Same behavior.
                          The timer functionality is implemented buggy. It works only in a normal loop but not with events.
                          sysdl132S 1 Reply Last reply Reply Quote 0
                          • sysdl132S
                            sysdl132 @M5StickFreakler
                            @m5stickfreakler Seems a UIFlow bug.You can contect the m5stack group.(Actually I have the same problem on an old device and a new device.They both has the problem.)
                            • M5StickFreaklerM
                              M5StickFreakler
                              thank you sysdl132 for confirmation this bug :-)
                              • world101W
                                This flow has issues because it's trying to fire a timer callback at the same time as the 1 second wait, which causes a blocking function. I do get a continuous beep as you describe, but I don't think it's a bug. I would consider it bad code design because you have two functions at 1 second firing at the same time, which causes blocking. You really only need the timer and not the 1 second wait function to achieve a beep ever 1 second.
                                M5StickFreaklerM 1 Reply Last reply Reply Quote -1
                                • M5StickFreaklerM
                                  M5StickFreakler @world101
                                  @world101 said in Speaker beep and Wait:
                                  As I mentioned earlier, the bug has nothing to do with the "Wait".
                                  You can check it by yourself:
                                  try it out and you will see what I mean :-)
                                  • world101W
                                    I tested this exact flow and let it run for over 20 minutes and I'm still getting beep every 1 second. I have no issues with this flow on the M5Stack Core Grey and M5Stack Fire. I'm using uiFlow 1.4.4 and firmware v1.4.4.
                                    • world101W
                                      I have no issues with this flow either. It's been running for more than 20 minutes along with the beep flow on my other m5stack.
                                      • M5StickFreaklerM
                                        I have the bug on every device here (3 different units), like user "sysdl132". I also use Firmware 1.4.4 (but its buggy in firmware 1.4.3 also)
                                        Simply use the "RUN" button and you will have the same UIFlow bug. Dont upload it into the device.
                                        M5StickFreaklerM world101W 2 Replies Last reply Reply Quote 0
                                        • M5StickFreaklerM
                                          M5StickFreakler @M5StickFreakler
                                          • M5StickFreaklerM
