    UIFlow 1.5.1
    15 Posts 6 Posters 27.3k Views 2 Watching
    • m5stackM Offline
      Ver 1.5.1. time : 2020.04.23
      UpdateLog:
      • 1: Fixed: SD card error.
      • 2: Fixed: Remote Error.
      • 3: Update: Mqtt can run in exec mode.
      • 4: Add: Mqtt add last will support (must be ahead in mqtt start).
      • 5: Add: ENV-II unit support.
      • 6: Add: I2C add data different format.
      • 7: Support Remote.
      • M5StickFreaklerM Offline
        M5StickFreakler
        Sorry since Update 1.5.x it is not possible, that I connect my devices via Usb.
        Upload fails.
        I use Desktop M5Flow 1.0.9
        I got this UIFlow-Error:
        [Window Title]
        Error
        [Main Instruction]
        A JavaScript error occurred in the main process
        [Content]
        Uncaught Exception:
        Error: Port is not open
            at SerialPort.close (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:425:29)
            at SerialPort.<anonymous> (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\src\libs\serialport.js:217:34)
            at SerialPort._error (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:197:14)
            at binding.open.then.err (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:241:12)
        [OK]
        I can Reset the device and then reconnect it.
        Then I see a green "connected" in left bottom corner.
        After I try to upload some code, I get ever and ever again an error and device is disconnected.
        Sometimes I can "run" my code.
        But if I upoload the code to the device I get an Error:
        File "<string>", line 1
        SyntaxError: invalid syntax
        First line in code is:
        from m5stack import *
        It is really unusable since some few weeks.
        Before it was working well (but not perfect)
          plusulli
          Where is the Demo for M5stickC ?
            I'm getting issues with using the earth unit on fw 1.5.1
            uiflow is calling adc instead of earth
              @m5stack FW1.5.1 and UIFLow web 1.5.1
              When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.
              • m5stackM Offline
                m5stack @ajb2k3
                @ajb2k3 OK, Thank you feedback. we will fix this bug as soon as possible
                • m5stackM Offline
                  m5stack @plusulli
                  @plusulli for the time being, M5StickC don't have 1.5.1 FW. pls patient wait.
                    ajb2k3 @m5stack
                    @m5stack AttributeError 'i2c' object has no attribute 'begin'
                    • m5stackM Offline
                      m5stack @ajb2k3
                      @ajb2k3 after what operation it return this error?
                        ajb2k3 @m5stack
                        @m5stack Sorry should have said.
                        Trying to use the NCIR unit on port A
                        • m5stackM Offline
                          m5stack @ajb2k3
                          @ajb2k3 ok......we will tracking this issues
                            @m5stack DCMotor and fan can not be controlled using PWM.
                            • G Offline
                              Guors
                              @m5stack FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!
                                Pumpui @M5StickFreakler
                                • m5stackM Offline
                                  m5stack @Guors
                                  @guors thank you feedback. we will fix this bug as soon as possible
