    Review "LORA"
    Lessons and Guides
    9
    9
    25.4k
    • DimiD
      Dimi
      Consider one of the many modules for M5Stack - "LORA" (Fig. 1). Buy it now on Aliexpress
      alt text
      Figure 1. The LORA module to the base and terminating modules
      This module is a plastic frame is blue, which are fastened by means of screws special printed circuit Board (Fig. 2) with two connectors 2 on 15, the antenna and the wireless module LORA Ra-02 (Fig. 3).
      On the frame on the right side (Fig. 4) embossed inscription LORA and seizure under a flat-blade screwdriver for easy removal of a module, because due to connector 2 of 15 modules are kept pretty tight.
      This module is designed to organize low-speed data transmission at frequencies 410-525 MHz at a relatively large distance from 1 (within city limits) to 10 km (in open areas) with low power consumption.
      alt text
      Figure 2. View of module top
      alt text
      Figure 3. The module on the back side
      alt text
      Figure 4. The module side
      • J
        Jay @Dimi
        @dimi Any plan for supporting 915MHz?
        • m5stackM
          915 and 868 are designing, we are testing the antenna.
          • E
            exquisitus @m5stack
            @m5stack so what's up on the testing?
            • dasloloD
              daslolo
              1 to 10 miles on low power? What are the applications? (besides decentralized internet ;)
              • D
                dda @daslolo
                @daslolo km not miles. And there are plenty of applications for long distance comms.
                • X
                  X-Dron
                  Is this module compatible with Sim800L?
                  Both use GPIO-5.
                  • JJJ
                    JJ @X-Dron
                    @x-dron
                    Hi X-Dron,
                    As you suspect, apparently this is a problem.... they need to be using different pins.
                    • qlionQ
                      qlion
                      Hi
                      Is there any update on the new 868 and 915 modules.
                      Just waiting for them.... :P
