    makey
    Scheduled Pinned Locked Moved PRODUCTS
    2 Posts 2 Posters 4.6k Views 1 Watching
    • J Offline
      jpilarski
      I am having some difficulty understanding the makey unit. I can make it beep if I put one end of a wire in the LED pin and touch other end of the wire to various pins. I get some sounds playing through the m5stack speaker and some on the makey's buzzer. Why are there multiple pins with the same number. Should I be able to just touch the pins with my hand and register a touch. Also can you explain how to use this device in UIFLOW. Again I can get a few beeps from the makey using UIFLOW but I'm not sure I understand the pins to use or how to work with the makey blocks. It did make some great beeps and I am excited to use. Last question is does the firmware on the mega328 ever need to be updated. thanks
      • ajb2k3A Offline
        ajb2k3 @jpilarski
        @jpilarski said in makey:
        This is the biggest issue that takes getting used to when moving from Atmega to esp32. The Atmega's pins are "Set function" in arduino however the esp32 using a mux controller to control the pins resaulting in a matrix of multi function I/O pins that need to have functions set in code.
