    2. iPodLux
    3. Topics
    I
    • Continue chat with iPodLux
    • Start new chat with iPodLux
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Topics created by iPodLux
    • I
      M5Stack-MegaChess - Any update?
      PROJECTS • • iPodLux
      0
      Votes
      6493
      Views
      https://drive.google.com/file/d/1Gx1Nh-VmZIU_m0ZbCK0UWXfuLv6L06Tq/view?usp=sharing
    • I
      Simple game sample, frustrating results - M5Flow
      Votes
      3805
      Views
      I
      @ipodlux Found it! in order to compensate the slow reading of the interrupt I moved the reading in the loop. It less less classy that the external function but now it reacts as it should.
    • I
      Ui Flow on iPad (almost neat...) useful if your iPad is the only piece of technology at hand...
      Lessons and Guides • • iPodLux
      Votes
      4912
      Views
    • I
      Ui Flow 1.3.2 (web) has dropped Stick
      Bug Report • • iPodLux
      9
      0
      Votes
      9
      11749
      Views
      @mati said in Ui Flow 1.3.2 (web) has dropped Stick: @ajb2k3 yes in old version ... there was any reply from official guys about it ? The offical answer was that it is obsolete and they don't need to support it.
    • I
      M5 How-to (general tips and guide)
      General • • iPodLux
      6
      Votes
      6
      11536
      Views
      E
      @ajb2k3 unfortunately the stick ahs no possibility to be switched into USB mode
    • I
      M5Stick (non C) USB mode
      M5 Stick/StickC • • iPodLux
      Votes
      4739
      Views
      I
      Hi Just trying to upload script to stick via usb (IDE). Either on mac or windows I can see stick usbslabtouart for erasing and firmware burn but it is not available to Ui Flow IDE to download the script. Core and Stick C work both well with Ui Flow IDE since they have usb option in their menu. No luck so far with Stick non-C
    • I
      Ui Flow upload made persistent?
      UIFlow • • iPodLux
      10
      Votes
      10
      15879
      Views
      R
      I use uPyCraft to load/write files. There is another graphics editors like Mu or Tonny
    • I
      Is the M5Cloud project on io.m5stack.com still alive
      Micropython • • iPodLux
      Votes
      4463
      Views
      @ipodlux said in Is the M5Cloud project on io.m5stack.com still alive: I stumbled on the webpage and looked at the github documentation. There is enough for coding question is last post is dated more than 1 year ago, is the project still on? No, it is depreciated and replaced with uiflow.
    • I
      UiFlow - 1.3.1 beta - Core - wifisetup
      UIFlow • • iPodLux
      Votes
      4566
      Views
      I
      @ajb2k3 now that you mention it... both M5Flow web and UiFlow IDE are V 1.2.3 I'll try to revert to fw 1.2.3 and see how it goes
    • I
      m5p2p for UIFlow (Solved)
      UIFlow • • iPodLux
      10
      0
      Votes
      10
      13671
      Views
      H
      thanks for your reply. Yeah, I just implemented a communication via the espnow broadcast block. Works ok, as long as the messages don't overlap. somehow I cannot get IDed messages to work. Have you ever succeeded with that?
