@robski If I set them manually in the GreenSwitch and whiteSwitch it works fine
Posts made by l.roca
RE: Unexpected results when using intensity slider for LED vontrolposted in UiFlow 2.0
Regarding previous posts about the green LED control: I’ve implemented an intensity slider, but it’s behaving unexpectedly. The light shifts to red instead of dimming the green. Interestingly, the color is correct when brightness is set manually to 100%. Does anyone have insight into what might be the reason?
Industrial Analog pH Meterposted in Features Wish List
Hi,
A good industrial pH Meter Kit will be great to have.
Thanks
RE: MOSFET unitposted in Features Wish List
@teastain can you please share the scheme how to built a MOSFET inside a M5Stack Proto Unit. Thanks
Unit CamS3 Wi-Fi Camera 5MP store images on cloudposted in Units
Hi,
Is there a way to store the Unit CamS3 Wi-Fi Camera 5MP images taken in intervals in different filenames directly to at a cloud service (e.g. google drive, one drive)?
Thanks
RE: GROVE2GROVE and 5V DC fanposted in Units
@teastain @felmue Thanks a lot. One further question: do I always have to give 5V via external power source?
@teastain Arduino code will also be fine ;-). How do I connect the fan to the unit?
Hi,
Following this post , how do I connect a 5V DC to the Grove2Grove unit?
A simple scheme will be very helpful (as I am a newbie)
Can it get the power directly from the Grove? Or I need external power supply?Thanks
