    2. PeterO
    P
    • Continue chat with PeterO
    • Start new chat with PeterO
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    PeterO
    @PeterO
    0
    Reputation
    6
    1821
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    PeterO Follow
    Posts made by PeterO
    • RE: Problems writing to SD Card
      @stoni99 , yes, I have the same issue with my "picky" M5Stack. Samsung 64GB EVO plus XC Speedclass 3 are working fine, but I can no longer find it on Amazon. Sometimes Sundisk 32GB V30 are working, but in the next insert they refuse to work. Is it really the card or the software?
      posted in FAQS
      P
      PeterO
    • RE: M5Stack speaker not working
      @petero I have to correct myself: The issue with the speaker is appearing with old M5Stack Core 1 versions as well, after I have used the new driver "CH34XSER_MAC". Very Strange!
      posted in PROJECTS
      P
      PeterO
      hello All,
      I have the same issue, it started with this new version 2021-0907 V2.61. M5Stack changed the driver that was the first unexpected issue. Ok I managed it and then I have found that SD card reading and writing is not possible, when I load a test Sketch. The factory test which is on a new device is working fine, that means the M5Stack is ok, but the library or my installation need an update. Have done that, but no luck.
      Today I have found that I am getting a Guru Meditation error, which goes away when I disable the // M5.Speaker.tone(1200);
      speaker command.
      Sorry that I do not have a fix yet, I need to investigate more and I would be happy if someone has an idea how to solve that issue.
      best regards
      Peter
      E (53174) ledc: freq_hz=0 duty_resolution=13
      Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero). Exception was unhandled.
      Core 1 register dump:
      PC : 0x4000d099 PS : 0x00060730 A0 : 0x800e89f2 A1 : 0x3ffb26c0
      A2 : 0x0f424000 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000
      A6 : 0x00060720 A7 : 0x00000001 A8 : 0x00000001 A9 : 0x00000000
      A10 : 0x00000000 A11 : 0x0f424000 A12 : 0x00060720 A13 : 0x3ffb26c0
      A14 : 0x007be1a8 A15 : 0x003fffff SAR : 0x00000001 EXCCAUSE: 0x00000006
      EXCVADDR: 0x00000000 LBEG : 0x40087571 LEND : 0x40087581 LCOUNT : 0xffffffff
      Backtrace:0x4000d096:0x3ffb26c00x400e89ef:0x3ffb26e0 0x400e4119:0x3ffb2720 0x400e0d9e:0x3ffb2760 0x400e0dc5:0x3ffb2780 0x400d5c5d:0x3ffb27a0 0x400dd723:0x3ffb2800 0x400e614d:0x3ffb2820
      posted in PROJECTS
      P
      PeterO
    • RE: Grove - Temperature & Humidity Sensor Pro
      @petero
      Have found the issue in the I2C scanner code. I have used Wire.begin(9600); instead of Wire.begin();
      The value 9600 is disturbing the whole thing,
      The Link to the SAM menu code is very very useful. JimiT, Thank you again,
      posted in FAQS
      P
      PeterO
      @jimit
      Thank you for the answers. Have tried to use some code in the link. Yes, my code is similar.
      Then I have isolated the I2C Scanner code and found a very confusing result, all addresses show up as active. Normally I expect to see only the actively used addresses as active.
      Here the Scanner code. On M5Stack LCD screen I see all addresses white, see picture.
      Is this really normal ?
      To check if the cable is broken I will try to connect with the pins and not with the Grove, but could be the unstable connection is in DHT12 module .
      And here the code I have used:
      // I2C Scanner code used from this link to check if M5Stack is working
      // https://github.com/PartsandCircuits/M5Stack-SAM/tree/master/M5Stack-SAM
      // confusing part is that all I2C addresses are found in scan. That is surprising for me, because in a
      // normal Arduino Uno(Mega you see only addresses which are actively used.
      // Peter Obermeier 28 April 2018
      #include <Wire.h>
      #include <M5Stack.h>
      Wire.begin(9600);
      void loop(){
      byte error, address;
      int nDevices;
      byte ridx = 0;
      byte lidx = 0;
      boolean scanrun = HIGH;
      // Create buttons
      M5.Lcd.setTextSize(2);
      M5.Lcd.setCursor(46,215);
      M5.Lcd.setTextColor(RED);
      M5.Lcd.printf("Scan");
      M5.Lcd.drawRect(42,212,55,30,WHITE);
      M5.Lcd.setCursor(135,215);
      M5.Lcd.setTextColor(GREEN);
      M5.Lcd.printf("Upd");
      M5.Lcd.drawRect(130,212,55,30,WHITE);
      M5.Lcd.setTextSize(1);
      M5.Lcd.setTextColor(WHITE);
      while(M5.BtnB.wasPressed()){
      while(!M5.BtnB.wasPressed()){
      if(scanrun==HIGH){
        scanrun = LOW;
        nDevices = 0;
        for(address = 1; address < 127; address++ ){
          ridx++;
          if(ridx==17){
            ridx = 1;
            lidx++;
          Wire.beginTransmission(address);
          error = Wire.endTransmission();
          if (error == 0){
            M5.Lcd.drawString(String(address,HEX),0+(ridx*18),45+(lidx*20),2);
            nDevices++;
          }else if (error==4){
            M5.Lcd.drawString(F("ER"),0+(ridx*18),45+(lidx*20),2);
          }else{
            M5.Lcd.drawString(F("--"),0+(ridx*18),45+(lidx*20),2);
      }else{
        if(M5.BtnA.wasPressed()){
          M5.Lcd.fillScreen(BLACK);
          M5.Lcd.setCursor(0,0);
          M5.Lcd.print("new scan will start now ... ");
          delay(2000);
          ridx = 0;
          lidx = 0;
          scanrun = HIGH;
      posted in FAQS
      P
      PeterO
      hi all,
      have the issue that temp and humidity are read with zero value. After spending a long time with trouble shooting and checking if the signals and power is correct ( the delivered grove cable has mixed up colors) I disconnected the sensor and connected again. Then the sensor was working fine,
      but only until the next power off/on action.
      Is this a common issue or an issue with a defect DHT12 sensor or M5Stack Unit ?
      posted in FAQS
      P
      PeterO
