    Lesson 1.2.1. LCD. How to create image array
    Lessons and Guides
    7
    15
    55.1k
    • DimiD
      Dimi
      Step 1. Download this program to convert the image into code С for the link here or GitHub here (Fig. 1);
      Note: the program requires a pre-installed NET.Framework 4.5 or newer.
      alt text
      Figure 1. Download the program from the website
      Step 2. Prepare any image format .bmp, .png or .jpg (Fig. 2);
      alt text
      Figure 2. The program folder and image
      Step 3. Drag with mouse the picture to the program icon and release (Fig. 3);
      alt text
      Figure 3. Drag and drop the image onto the program icon
      Step 4. Starts a console application which will show the status in percentage (Fig. 4);
      alt text
      Figure 4. Running the conversion process
      Step 5. After the program automatically closes and the folder appears a file with the image name and extension .c (Fig. 5);
      alt text
      Figure 5. Received .c file with array of image
      Step 6. Create a new sketch using the Arduino IDE (see previous tutorials) and save it to our folder, then move .c file in the folder with the sketch (Fig. 6);
      alt text
      Figure 6. The folder and sketch .c-file inside our folder
      Step 7. Go to the folder with the sketch and open the sketch (Fig. 7, 8);
      alt text
      Figure 7. The folder with the sketch
      alt text
      Figure 8. New sketch in the Arduino IDE
      Step 8. Use following code to connect .the c-file and display the image on the screen (Fig. 9). Note that on line 3 you need to write your name.the c-file, for example dukeprofile;
      alt text
      Figure 9. Our sketch
      Step 9. Click the Upload button (Fig. 10) in order to flash the device;
      alt text
      Figure 10. Upload the firmware to the device
      Step 10. When the device firmware is completed, the device screen will appear with the image (Fig. 11).
      alt text
      Figure 11. The image on display
      • X
        xbcke1234
        @dimi 在 Lesson 1.2.1. LCD. How to create image array 中说:
        link
        The program that converts image into code C "link" is invalid. Could you update new one? Appreciate!
        • JJJ
          JJ @xbcke1234
          @xbcke1234 Hi Xbcke1234,
          Do you mean that the first link to download the files is not working ? Or do you mean you have downloaded the program and it is not working for you?
          Note that the lesson also lists a github link which has the image conversion program - it should work. I've copied the link below....
          The exe file is located in: ConsoleApplication1\obj\Release
          https://github.com/dsiberia9s/ImageToCode
          • X
            xbcke1234 @JJ
            @jimit
            Thank you for the quick reply. I was mean the first download link not working as Figure 1. But after you point out the .exe file location - is work for me now. Thanks!!!
            JJJ DimiD 2 Replies Last reply Reply Quote 1
            • JJJ
              JJ @xbcke1234
              @xbcke1234 Hi, no problem !
              Be sure to check out Dimi's recent lesson if you haven't already:
              http://forum.m5stack.com/topic/130/lesson-7-mpu9250-game-space-defense-beta
              • DimiD
                Dimi @xbcke1234
                @xbcke1234 ok, i make new version on this week with auto size mode
                • world101W
                  world101
                  Is there an equivalent “image to code C” program for a Mac?
                  DimiD ajb2k3A 2 Replies Last reply Reply Quote 0
                  • DimiD
                    Dimi @world101
                    @world101 sorry, I dont have Mac. maybe
                      ajb2k3 @world101
                      @world101 在 Lesson 1.2.1. LCD. How to create image array 中说:
                      Not found one but there is an online tool.
                      DimiD 1 Reply Last reply Reply Quote 0
                      • DimiD
                        Dimi @ajb2k3
                          ajb2k3 @Dimi
                          @ajb2k3 https://yadi.sk/d/j9ryFVn83XXmkf
                          @Dimi - I am also a Mac users and can't use exe's
                          • P
                            paahaa @ajb2k3
                            @ajb2k3 not sure if you haven't found it yet, but, on linux, I use Wine, a windows emulator with which you can execute .exe
                            Here's the link:
                            https://www.winehq.org/
                              ajb2k3 @paahaa
                              @paahaa said in Lesson 1.2.1. LCD. How to create image array:
                              Here's the link:
                              Thanks, but this guide is out of date now that I have worked out and documented how to make images work.
                                mikemoy
                                This seems like a great tool, but the link no longer works.
                                • DimiD
                                  Dimi @mikemoy
                                  @mikemoy Oh! Sorry. You can download this app here: https://ru.m5stack.com/downloads/Image2Code.exe
