    LLM Module
    14 Posts 5 Posters 8.6k Views 1 Watching
    • teastainT Offline
      teastain @Bipman
      @Bipman It's all here, mate!
      https://docs.m5stack.com/en/module/Module-LLM
      What you are suggesting is a bit of a challenge, but do-able, I guess.
      The Cores make a nice power-and-interface though.
      • B Offline
        Bipman @teastain
        @teastain OK, ta. For some reason it won't go into programming mode either. I've tried the 'hold button and add power' but it just goes to the green 'on' light. I've tried everything and I have added the driver first. Been through all the docs and not sure what I'm missing.
        Steve
        • teastainT Offline
          teastain @Bipman
          @Bipman Right at the bottom of the link I sent you:
          And here:
          https://docs.m5stack.com/en/guide/llm/llm/arduino
          and
          https://github.com/m5stack/M5Module-LLM
          • B Offline
            Bipman @teastain
            @teastain Sorry to be really thick but how does that help set it into programming mode? Love the signature by the way, I also have way too many units and modules!
            Steve
            • teastainT Offline
              teastain @Bipman
              @Bipman
              It?
              The LLM or the CoreS3?
              What programming language/IDE do you use?
              I don't have an LLM, so I am offering generic M5/ESP32S3 advice!
              • B Offline
                Bipman @teastain
                @teastain Ah, OK! I have the CoreS3 with the LLM attached. It's the LLM unit I'm having issues with in that it won't go into programming mode.
                Steve
                  ajb2k3 @Bipman
                  @Bipman I don't have one at present but I wonder how we'll it will work with the CoreMP135.
                    Snyder_br
                    Hello guys,
                    A basic question: how can I connect (plug physically) a LLM module to Core 2?
                    Thanks,
                    • teastainT Offline
                      teastain @Snyder_br
                      @Snyder_br
                      Yes.
                      Bottom of the docs:
                        Snyder_br @teastain
                        @teastain Thanks for answer but the Pin doesn't fit. Its necessary to remove original battery (Core 2) to plug-in the LLM module? have some pictures?
                          ajb2k3 @Snyder_br
                          @Snyder_br Yes, you have to remove the bottom plate/battery to connect modules.
