    LLM Module
    14 Posts 5 Posters 9.0k Views 1 Watching
    • B Offline
      Bipman @teastain
      @teastain OK, ta. For some reason it won't go into programming mode either. I've tried the 'hold button and add power' but it just goes to the green 'on' light. I've tried everything and I have added the driver first. Been through all the docs and not sure what I'm missing.
      Steve
      • teastainT Offline
        teastain @Bipman
        @Bipman Right at the bottom of the link I sent you:
        And here:
        https://docs.m5stack.com/en/guide/llm/llm/arduino
        and
        https://github.com/m5stack/M5Module-LLM
        • B Offline
          Bipman @teastain
          @teastain Sorry to be really thick but how does that help set it into programming mode? Love the signature by the way, I also have way too many units and modules!
          Steve
          • teastainT Offline
            teastain @Bipman
            @Bipman
            It?
            The LLM or the CoreS3?
            What programming language/IDE do you use?
            I don't have an LLM, so I am offering generic M5/ESP32S3 advice!
            • B Offline
              Bipman @teastain
              @teastain Ah, OK! I have the CoreS3 with the LLM attached. It's the LLM unit I'm having issues with in that it won't go into programming mode.
              Steve
                ajb2k3 @Bipman
                @Bipman I don't have one at present but I wonder how we'll it will work with the CoreMP135.
                  Snyder_br
                  Hello guys,
                  A basic question: how can I connect (plug physically) a LLM module to Core 2?
                  Thanks,
                  • teastainT Offline
                    teastain @Snyder_br
                    @Snyder_br
                    Yes.
                    Bottom of the docs:
                    https://docs.m5stack.com/en/module/Module-LLM
                      Snyder_br @teastain
                      @teastain Thanks for answer but the Pin doesn't fit. Its necessary to remove original battery (Core 2) to plug-in the LLM module? have some pictures?
                        ajb2k3 @Snyder_br
                        @Snyder_br Yes, you have to remove the bottom plate/battery to connect modules.
