    M5StickC usb driver and Catalina
    30 Posts 12 Posters 130.0k Views 2 Watching
    • m5stackM Online
      m5stack @tcruse
      @tcruse first , on some Mac PC, M5StickC cannot upload program properly.
      the solution: When programming, short the G0 to GND using the DuPont line.
      and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
      FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
        sheepDog @m5stack
        @m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
        1. If I connected a M5Stack I saw:
        2. If I connected a M5StickC I saw:
        You can check the loaded drivers and their versions in terminal with "sudo kextstat".
        I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
          sheepDog
          I formulated an Issue at Github: Link to Issue
          Supplement on January 18, 2020: You need an Espressif account to see the issue.
          • m5stackM Online
            m5stack @sheepDog
            D S 2 Replies Last reply Reply Quote 0
              diogovaraujo @m5stack
              @m5stack Cant click that link.
                sheepDog @m5stack
                @m5stack
                I got this error if I click your link: "Access denied. You do not have permission to access this page."
                Thank you for updating your software.
                • world101W Offline
                  world101
                  The link worked for me once a few hours ago, but now it’s not.
                  • N Offline
                    nsfilho @o.copleston
                    @o-copleston This solution is running perfectly! Thank you!
                    • m5stackM Online
                      m5stack @diogovaraujo
                      It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
                        sheepDog @m5stack
                        @m5stack Hello, are there any news about a solution for Catalina and M5StickC?
                        • N Offline
                          nsfilho @sheepDog
                          @m5stack if you can, please give us the link for a new driver to solve that problem....
                          • m5stackM Online
                            m5stack @nsfilho
                            @nsfilho @sheepDog Please read the information carefully before using the tool
                            link:
                            http://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-platform-can-t-upload-programs-solustion
                            • N Offline
                              nsfilho @m5stack
                              @m5stack Thank you! The solution 2 (as describe in link) is fully functional.
