🀖Have you ever tried Chat.M5Stack.com before asking??😎
Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Cellular UIFlow blocks
    5k Views
    T
    More specifically I need to know if the Arduino code downloadable here can be alternatively implemented by means of the UIFlow blocks belonging to the Cellular palette and, if so, I'd be interested to know how. Thanks
  • Trying to get stick V working
    3k Views
  • UIFlow MQTT topic single level wildcard '+'
    5k Views
    T
    Thanks a lot, I rescued this limitation (which makes the mqtt client not compliant to the standard) by setting properly the server side
  • issue with lego+ aka DC Motor module
    6k Views
    SkinkS
    @hetzer said in issue with lego+ aka DC Motor module: I cant make lego+ aka dc motor module. It gives error" moduel' object has no attribute Legoboard. Can anyone assist? I guess you are using the wrong commands in UIFlow 1.6.3. The (DC motor (Lego+) module) and its control commands UIFlow 1.6.3[image: 1600225081648-dc-modul-resized.jpg] [image: 1600225132010-dc-motor-modul-resized.jpg] The (BaseX module) and its control commands UIFlow 1.6.3 [image: 1600225213172-xbase-modul-resized.jpg] [image: 1600225273120-xbase-resized.jpg] In the description of the (DC motor (Lego+) module) the picture may be confusing because there are the commands M1 etc., but these commands are for the BaseX module and not the (DC motor (Lego+) module) !
  • Emoji with M5 Fire
    8k Views
    F
    Thanx I used the old M5burner, as the new one is for Windows10. Apparently it is ok with windows 7 too
  • Atom Stepmotor minimum code
    3k Views
  • HTTP Block Gives Error
    13k Views
    G
    @world101 sorry for delay on answering. Many thanks it works as expected! In the meanwhile i tried with upython language also to manage more complex json structures.
  • GPS and LoRaWAN Modules together
    1 Votes
    4k Views
  • [Mac OS] UIFlow IDE copy paste don't works
    1 Votes
    4k Views
  • Quick average demo
    3k Views
    world101W
    👍🏻 thanks
  • How to get the position on X and Y of an object?
    6k Views
    Wow, thank you, sure this works.
  • Guidance on operatinal mode
    4k Views
  • Esp now m5stickC problem
    11k Views
    P
    Hi all, Very curious to give something similar a go. Driving a 5V motor over ESP now using the Joystick Unit at the transmit end. 2 x M5 Stack. Anybody have a UI Flow file I can modify? Kind regards, Paul
  • PYP SIM800L
    8k Views
    E
    Nothing spectacular either trials via module or the example do not work what is the order to initiate GPRS transmition - upload to a server? This second attempt throws name 'pyb' isn't defined from m5stack import * from m5ui import * from uiflow import * import module setScreenColor(0x222222) Driver for SIM800L module (using AT commands) MIT License; Copyright (c) 2017 Jeffrey N. Magee https://github.com/jeffmer/micropython-upyphone import math kludge required because "ignore" parameter to decode not implemented def convert_to_string(buf): try: tt = buf.decode('utf-8').strip() return tt except UnicodeError: tmp = bytearray(buf) for i in range(len(tmp)): if tmp[i]>127: tmp[i] = ord('#') return bytes(tmp).decode('utf-8').strip() class SIM800LError(Exception): pass def check_result(errmsg,expected,res): if not res: res = 'None' #print(errmsg+res) if not expected == res and not res == 'None': raise SIM800LError('SIM800L Error {} {}'.format(errmsg,res)) class SIM800L: def __init__(self,uartno): # pos =1 or 2 depending on skin position self._uart = pyb.UART(uartno, 9600, read_buf_len=2048) self.incoming_action = None self.no_carrier_action = None self.clip_action = None self._clip = None self.msg_action = None self._msgid = 0 self.savbuf = None self.credit = '' self.credit_action = None def callback_incoming(self,action): self.incoming_action = action def callback_no_carrier(self,action): self.no_carrier_action = action def callback_clip(self,action): self.clip_action = action def callback_credit_action(self,action): self.credit_action = action def get_clip(self): return self._clip def callback_msg(self,action): self.msg_action = action def get_msgid(self): return self._msgid def command(self, cmdstr, lines=1, waitfor=500, msgtext=None): #flush input #print(cmdstr) while self._uart.any(): self._uart.readchar() self._uart.write(cmdstr) if msgtext: self._uart.write(msgtext) # if waitfor>1000: # pyb.delay(waitfor-1000) buf=self._uart.readline() #discard linefeed etc #print(buf) buf=self._uart.readline() #print(buf) if not buf: return None result = convert_to_string(buf) if lines>1: self.savbuf = '' for i in range(lines-1): buf=self._uart.readline() if not buf: return result #print(buf) buf = convert_to_string(buf) if not buf == '' and not buf == 'OK': self.savbuf += buf+'\n' return result def setup(self): self.command('ATE0\n') # command echo off self.command('AT+CRSL=99\n') # ringer level self.command('AT+CMIC=0,10\n') # microphone gain self.command('AT+CLIP=1\n') # caller line identification self.command('AT+CMGF=1\n') # plain text SMS self.command('AT+CALS=3,0\n') # set ringtone self.command('AT+CLTS=1\n') # enabke get local timestamp mode self.command('AT+CSCLK=0\n') # disable automatic sleep def wakechars(self): self._uart.write('AT\n') # will be ignored # pyb.delay(100) def sleep(self,n): self.command('AT+CSCLK={}\n'.format(n)) def sms_alert(self): self.command('AT+CALS=1,1\n') # set ringtone # pyb.delay(3000) self.command('AT+CALS=3,0\n') # set ringtone def call(self,numstr): self.command('ATD{};\n'.format(numstr)) def hangup(self): self.command('ATH\n') def answer(self): self.command('ATA\n') def set_volume(self,vol): if (vol>=0 and vol<=100): self.command('AT+CLVL={}\n'.format(vol)) def signal_strength(self): result = self.command('AT+CSQ\n',3) if result: params=result.split(',') if not params[0] == '': params2 = params[0].split(':') if params2[0]=='+CSQ': x = int(params2[1]) if not x == 99: return(math.floor(x/6+0.5)) return 0 def battery_charge(self): result = self.command('AT+CBC\n',3,1500) if result: params=result.split(',') if not params[0] == '': params2 = params[0].split(':') if params2[0]=='+CBC': return int(params[1]) return 0 def network_name(self): result = self.command('AT+COPS?\n',3) if result: params=result.split(',') if not params[0] == '': params2 = params[0].split(':') if params2[0]=='+COPS': if len(params)>2: names = params[2].split('"') if len(names)>1: return names[1] return '' def read_sms(self,id): result = self.command('AT+CMGR={}\n'.format(id),99) if result: params=result.split(',') if not params[0] == '': params2 = params[0].split(':') if params2[0]=='+CMGR': number = params[1].replace('"',' ').strip() date = params[3].replace('"',' ').strip() time = params[4].replace('"',' ').strip() return [number,date,time,self.savbuf] return None def send_sms(self,destno,msgtext): result = self.command('AT+CMGS="{}"\n'.format(destno),99,5000,msgtext+'\x1A') if result and result=='>' and self.savbuf: params = self.savbuf.split(':') if params[0]=='+CUSD' or params[0] == '+CMGS': return 'OK' return 'ERROR' def check_credit(self): self.command('AT+CUSD=1,"*100#"\n') def get_credit(self): return self.credit def delete_sms(self,id): self.command('AT+CMGD={}\n'.format(id),1) def date_time(self): result = self.command('AT+CCLK?\n',3) if result: if result[0:5] == "+CCLK": return result.split('"')[1] return '' def check_incoming(self): if self._uart.any(): buf=self._uart.readline() # print(buf) buf = convert_to_string(buf) params=buf.split(',') if params[0] == "RING": if self.incoming_action: self.incoming_action() elif params[0][0:5] == "+CLIP": params2 = params[0].split('"') self._clip = params2[1] if self.clip_action: self.clip_action() elif params[0][0:5] == "+CMTI": self._msgid = int(params[1]) if self.msg_action: self.msg_action() elif params[0][0:5] == "+CUSD": if len(params)>1: st = params[1].find('#') en = params[1].find('.',st) en = params[1].find('.',en+1) if st>0 and en>0: self.credit = '£'+params[1][st+1:en] if self.credit_action: self.credit_action() elif params[0] == "NO CARRIER": self.no_carrier_action() # http get command using gprs def http_get(self,url,apn="giffgaff.com"): resp = None rstate = 0 proto, dummy, surl = url.split("/", 2) is_ssl = 0 if proto == "http:": is_ssl = 0 elif proto == "https:": is_ssl == 1 else: raise ValueError("Unsupported protocol: " + proto) try: # open bearer context res = self.command('AT+SAPBR=3,1,"Contype","GPRS"\n') check_result("SAPBR 1: ",'OK',res) res = self.command('AT+SAPBR=3,1,"APN","{}"\n'.format(apn)) check_result("SAPBR 2: ",'OK',res) res = self.command('AT+SAPBR=1,1\n',1,2000) check_result("SAPBR 3: ",'OK',res) # now do http request res = self.command('AT+HTTPINIT\n',1) check_result("HTTPINIT: ",'OK',res) res = self.command('AT+HTTPPARA="CID",1\n') check_result("HTTPPARA 1: ",'OK',res) res = self.command('AT+HTTPPARA="URL","{}"\n'.format(surl)) check_result("HTTPPARA 2: ",'OK',res) res = self.command('AT+HTTPSSL={}\n'.format(is_ssl)) check_result("HTTPSSL: ",'OK',res) res = self.command('AT+HTTPACTION=0\n') check_result("HTTPACTION: ",'OK',res) for i in range(20): #limit wait to max 20 x readline timeout buf = self._uart.readline() if buf and not buf==b'\r\n': buf = convert_to_string(buf) #print(buf) prefix,retcode,bytes = buf.split(',') rstate = int(retcode) nbytes = int(bytes) break res = self.command('AT+HTTPREAD\n',1) buf = self._uart.read(nbytes) check_result("HTTPACTION: ",'+HTTPREAD: {}'.format(nbytes),res) if buf[-4:] == b'OK\r\n': # remove final OK if it was read buf = buf[:-4] resp = Response(buf) except SIM800LError as err: print(str(err)) self.command('AT+HTTPTERM\n',1) # terminate HTTP task self.command('AT+SAPBR=0,1\n',1) # close Bearer context return resp def test(self): r = self.http_get('http://exploreembedded.com/wiki/images/1/15/Hello.txt') print(r.text) class Response: def __init__(self, buf, status = 200): self.encoding = "utf-8" self._cached = buf self.status = status def close(self): self._cached = None @property def content(self): return self._cached @property def text(self): return str(self.content, self.encoding) def json(self): import ujson return ujson.loads(self.content) phone = SIM800L(1) print(phone.signal_strength())
  • UIFlow for Atom Echo
    6
    12k Views
    world101W
    @m5stack regarding the Attention note, will it damage the Atom Echo to play streaming music over BLE for long periods (several songs or hours of streaming music)?
  • HttpPost using UIflow
    13
    26k Views
    R
    @franco see the python code tab. The urequests statement comes immediately after the try statement. If something goes wrong, e.g. a typo in the address (non-existent address), this requests instruction will be treated as if it never started and the blocks Get Data and Get Status Code will not return anything and probably their use in this case cause a error.
  • GPS-Unit: Missing speed value
    8k Views
    m5stackM
    @gaviota In subsequent updates we will add it.
  • How Do I connect ENV II in UIFlow
    5k Views
    SkinkS
    @jhonnytank said in How Do I connect ENV II in UIFlow: I am trying to connect env II in UIFlow. In the Unit-Slector it is crossed out. Is there a method to add a suitable driver? Yes you have to take the UIFlow 1.6.0 Beta Version where you can select both ENV Units again ! Skink See Picture :[image: 1595075697711-uiflow-1.6.0-env-einheit-resized.jpg]
  • change the speed of only one of the three motors.
    6k Views
    moon3jpM
    @m5stack disappointment!!
  • How to use the infrared Diode in UI-Flow?
    5k Views
    C
    @jhonnytank It turned on by setting pin 9 to low. I don't believe there is a photodiode; so I am picking up a arduino remote kit to read my remote a week from Friday. I can post my results when I have them if you want.
