Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Support multiple files
    8k Views
    m5stackM
    @jesuslg123 oh ~i see... you mean is hope user could create some page. and use block to control which page will display in the screen? right? .. that is a good idea , actually our engineer have ever considered this. so maybe this function will in the future release.
  • HTTP Get - Empty response body
    9
    18k Views
    J
    So, I could workaround this issue after some work and before close and forget this thread here forever, let me share it: The problem: GoPro wifi API is not fully following the HTTP protocol specifications. Headers and body content is separated by \n instead of \r\n uRequests library is very strict on response parsing, while mostly any other libraries/browser/etc handle requests with some "malformed" bodies, uRequests does not. UIFlow IDE solution: Upload to the Stick5C the modified version of uRequests [image: 1594223907346-screenshot-2020-07-08-at-17.39.09.png] Override the uRequests library usage with a new import using execute code block. [image: 1594223971529-screenshot-2020-07-08-at-17.37.42.png] From that moment on (only on this app) it will use the modified library. No UIFlow IDE solution: Stop using UIFlow IDE 😢 Upload to the Stick5C the modified version of uRequests Use Visual Studio code or any other IDE to continue the development. Override the uRequests library usage with a new import on the code. I hope this is useful to someone else, any suggestion is also more than welcome. Thanks 😄
  • upload via USB from the desktop-Version of UI-Flow
    11k Views
    J
    @lukasmaximus Thank you, that helped
  • M5 Stick C - receiving data over WIFI
    9k Views
    N
    Thanks for the swift answer dclaar. I completely ignored the Remote section as it had blocks referring to sliders and buttons. I should have realized! I have gotten that working without any problem. However from what I can see it uses the M5Stack WEB site to create a small WEB server or at least redirect traffic which would be fine for most applications. However, what I need is to be able to send something using POST from my PC on my local network. (It could be JSON or plain text). My M5StickC already has a fixed IP. I don't think any of the options you suggest will do what I need in Blockly, so am I stuck with moving to python, or do you have any more suggestions! Thanks
  • invert RX/TX serial lines (in UIFlow / Micropython)
    6k Views
    J
    I have a very special board I need co communicate with. Currently I use the Arduino serial option to invert the signals. But I would prefer to prototype in UIFlow Are there any plans to upgrade to micro python 1.12, soon. I am really missing several options in your current implementation with micropython 1.11 al would easily work with 1.12: mDNS, BLE,, and inverting RX/TX in UART Thanks
  • uiflow non-volatile memory - save variables
    6k Views
    B
    Thanks, I see eeprom option when I change ver to beta in UIFlow. Data in is stored as strings, that simplifies things.
  • Fall detection in M5Stick-C
    4k Views
    ajb2k3A
    I started one and shared it on hackster.io but never had time to revisit the project !
  • TOF hat maybe not connect
    4k Views
    J
    After some trys I made it work.
  • M5 StickC UI flow
    4k Views
    m5stackM
    maybe you could package the block be a function. then use it in the main process
  • How to set data type and intial values.
    8k Views
    B
    [image: 1592860979153-40e7c48f-ca80-431d-82c3-efcb57ba89cd-image.png] Converts to; if bRunFan and bRunFan != bRunFanOld: fPvHrs = 0.01 if bTm6min and bRunFan: fPvHrs = fPvHrs + 0.01 bRunFanOld = bRunFan Thanks M5stack, this worked. I didn't want to divide by 10 because I would have to do that everywhere, slow the execution speed, its a slippery slope. The esp32 has very long divide instruction time compared to addition and multiplication.
  • Button Error
    7k Views
    B
    @m5stack Its ok thanks, problem solved. I gave the text label the name 'btnA' which is already a M5stack function, so renamingthe label cleared the problem.
  • Adding external libraries via uiflow
    25
    102k Views
    R
    If you use Visual Code you could install this extension https://marketplace.visualstudio.com/items?itemName=curdeveryday.vscode-m5stack-mpy Then transfer your modified library to flash. It would be good to change the name to another one, so that the import function does not load the built-in urequests library. Alternatively, you would have to look in what order and from which locations the libraries are imported.
  • What does m5base.app_start() do?
    6k Views
    J
    @robalstona Yes I get that. But WHY? As I mentioned earlier, this makes testing code uploads a pain.
  • "Smart" network configuration from UIFlow?
    9k Views
    J
    @devilstower have you tried using the scan method described here? https://docs.micropython.org/en/latest/library/network.html
  • Changing Networks in UIFlow?
    6k Views
    D
    Yes, it sounds like this is what will be needed. It would be great if UIFlow would just roll up the whole sequence of switching to AP mode, collecting the info, and reconnecting. It's such a standard behavior for ESP-based devices, that it seems like it should be baked-in.
  • UiFlow MQTT topics
    8k Views
    m5stackM
    @jhfoo yeah. i have ask our engineer. for the time being. UIFlow MQTT can't use ’topics/#‘ to subcribe all belong to "topics/....." topics.
  • M5StickC: Graduating from UiFlow: writing Python via REPL
    8k Views
    J
    @lukasmaximus Not to be taken as Thonny being an inferior app; my Windows has a lot of crap inside. It seems pymakr on VS Code is more reliable on my Windows. pymakr has its own quirks; one of which is refusing to download binary files (eg. images). Will wait for more motivation to revisit Thonny again.
  • Fire PSRAM not recognized
    6
    1 Votes
    8k Views
    lukasmaximusL
    @acuralegendz when you start uiflow desktop or m5 burner make sure to choose allow incoming network connections. The software needs to connect to the server so it can get the latest firmwares
  • This topic is deleted!
  • How to get UI Flow on to device?
    14
    31k Views
    P
    @kgobes Yes Visuino is block coding, I thought that what you were after wanting to use UiFlow. Of course the latter can display the dose as well. Cheers !
