Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • This topic is deleted!
  • How to get UI Flow on to device?
    14
    32k Views
    P
    @kgobes Yes Visuino is block coding, I thought that what you were after wanting to use UiFlow. Of course the latter can display the dose as well. Cheers !
  • UIFlow - Where is the Firmware?
    7
    15k Views
    L
    @lukasmaximus Hi. I just replayed the first video you mentioned and yes this is very helpful. You clearly state in this video how I can find the additional modules I need to add to the basic micropython to support the M5Stick. I much prefer to program at the low level python level rather than use something like UIFlow. Thanks again for your help.
  • Ui Flow upload made persistent?
    10
    1 Votes
    24k Views
    R
    I use uPyCraft to load/write files. There is another graphics editors like Mu or Tonny
  • UIFlow Desktop can't connect to M5Stick
    8k Views
    lukasmaximusL
    Check out this video I did a while back on using M5Stack devices on linux https://www.youtube.com/watch?v=ZZdTl0400uM you need to make sure to add the device to the dialout group, I can't remember the exact line of code but it's in the video if you watch it
  • IMU Get ACC reports gyro
    6k Views
    ajb2k3A
    it could be that the gyro is in Gravities which would explain the low reading. I was watching a vid and normally the readings shoud be in miligravities.
  • How to make M5StickC go into light sleep?
    -1 Votes
    11k Views
    J
    @m5stack Did a quick machine.deepsleep(10000) test and it seems to work! Will add more code to see how this extends battery life. Thanks!
  • Subscribing to MQTT doesn't work
    8
    13k Views
    world101W
    @lederschnautz Great. Glad I could help.
  • UI flow - connexion problem usb port
    6
    8k Views
    ajb2k3A
    @bww1340 Repost this one in the official updates forum under the 1.5.1 (or which ever version you are struggling with.)
  • UIFlow Desktop on MacOS mojave 10.14.5 cannot connect to Faces Dev Kit
    10
    15k Views
    indrajaalI
    @lukasmaximus thanks for verifying that my setup is correct. Will check out the urequests video as well. Fortunately, USB mode is working for me, so, for now, I'll just use that to play around with my Faces dev kit. Thanks y'all for the help 🙏🏽
  • Custom Hostname
    4k Views
  • Resource Manager cant Load blocklys
    4k Views
    X
    @xis After some attempts it worked.
  • UIFlow and unit grove ultrasonic distance sensor
    7
    16k Views
    S
    Thank you.You re right, i send that post after i tried that module. That HCSR-04 module isn't for Grove, it use 4 pins (VCC, ground, trigger pin, echo pin) . It works very well but.. This is my project : i have a mini-robot made with arduino (Uno, motor shield, ultrasonic sensor, servo) and i want to make it again in M5Stack and micropython context. So i bought the GOPlus element that provides controls for 4 servos connexions, 2 independant motors, 3 more grove ports. The problem is : when i use at the same time 1 servo and the basic 4 pins Ultrasonic function, the Echo Pin creates an ERROR on the M5Stack . That s why i wanted to try the grove Ultrasonic. But it s using only 1 pin for trigger and echo.
  • 0 Votes
    8k Views
    S
    This worked well for me with pin 21 (trigger) and pin 22 (echo) https://github.com/rsc1975/micropython-hcsr04
  • UiFlow needs https
    2 Votes
    7k Views
    world101W
    @m5stack Thank you!
  • text formatting
    8k Views
    R
    @fonzies83 try this commands [image: 1587847760098-img_20200425_224437444_hdr-2-resized.jpg]
  • UIFLOW Measure input pulse
    6k Views
    lukasmaximusL
    @PhilG1300 the latest Uiflow firmware 1.5.0 is based on micropython v1.12 which introduced a new feature called RMT, https://docs.micropython.org/en/latest/library/esp32.html#rmt it supposedly can generate and receive pulses as low as 12.5ns, I haven't experimented much with this library, but it may serve your purpose. To use those micropython commands you could just paste them into an execute block in your code
  • UIFlow basics, few beginner questions
    6
    11k Views
    S
    I don't know why but, now i have the SD card items in Advanced Menu. May be because i plugged once a SD card ? The white cross icon to add UNITS is here too. I ve notice that : when modification is done with Blocky and i save the file : the saved file is OK, when the same modification is done with micropython : the file can't be saved. As if the micropython screen wasn't really a part of the UIflow. Related to the issue n°4 above ??
  • Ui Flow support for onewire and ds18x20
    26
    101k Views
    K
    U mnie działa bardzo dobrze. Dzięki
  • Combining files?
    6
    11k Views
    C
    @dclaar I'm using 2 techniques: Use Notepad++ as an editor. If you name your program *.py, it will highlite the code as in Blockly/Python. You can then copy and paste the code into UIflow (but you cant save them there). So if the code works, I copy and paste the code back into Notepad++ and save it as a *.py file. Using the standard editor programming ESP32 and ESP8266 in microphyton: yPyCraft or Thonny (https://randomnerdtutorials.com/getting-started-micropython-esp32-esp8266/). The UIFlow Python editor probably is a clone of one of these. With these editors you can even do a simple code/syntax check, then copy and paste back and forth as I described with Notepad++.
