Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • GPS Base in UIFlow Blockly
  • AP+Webserver+Remote as UIFlow blocky
    1 Votes
    4k Views
  • This topic is deleted!
  • UIFlow keyboard shortcuts (macOS)
    ajb2k3A
    @mista said in UIFlow keyboard shortcuts (macOS): I am a new user of UIFlow and struggle with the desktop editor. For example I have not figured out the keyboard shortcuts for most standard editing functions. For example hitting Command+V (C,...) does nothing. So I am not able paste (copy, cut,...) any text into (from) blocks. Is there a list of keyboard shortcuts somewhere to learn from? I am sure I am doing something wrong but have no idea what it is. Thanks for your support. There are no keyboard shortcuts and so you can not copy and paste into UIflow.
  • Thermal unit not selectable in UIFlow
    uiflow
    7k Views
    C
    @dario I had the same issue, using UiFlow Beta as a version I see UiFlow 1.8.2 and for both Core2 as well as Fire I can see and add them (the THERMAL unit). Only issue I personally now have is that I have a pretty unstable connection from the Fire or Core2 to the web IDE so I can't really apply the 1.8.2 blockly code. And the Desktop IDE at the moment is stuck at 1.7.5 that can't handle the files I save using version 1.8.2. Maybe for you with a stable UiFlow internet connection you can use version 1.8.2 to test and deploy your Thermal code. Make sure to ofcourse burn 1.8.2 to your device also.
  • DIY Examples, where?
    1 Votes
    8k Views
    T
    I'm now busy doing the SHT30 with I2C. If I may pick you brain a little more. The label blockly seems to choose itself how to show the data. Decimal, binairy, text. I want it to show a list (or sub-item) only binary. Now it's mixed. Have been seaching now for an hour or so. Can't find it how. Do you know how?
  • REMOTE+ Slider for motors
    11
    20k Views
    W
    Finally, I've got it working using the map-block from Easy I/O in UIFlow (by chance I found it!), which is just def slider_Motor_callback(slider_value): motion.set_motor_speed(2, map_value(slider_value, 0, 100, -127, 127)) without any translation. Works fine with Remote+
  • Interrupt routine for remote switch in UIFlow
    8k Views
    m5stackM
    @werner_g that's what I mean. haha. you did it.
  • Why the newest UIFlow does not support BaseX anymore?
    11k Views
    m5stackM
    fixed.
  • UIFlow Remote+ Set image url
    5k Views
    m5stackM
    thank you :)
  • Can I upload wav files to the Core 2 without using a microSD card?
    4k Views
    W
    You can send a wav file to core2 using the beta version of the online UiFlow (v.1.8.2 is the latest as of today). on UiFlow, select "VER" icon on the menu bar and select BETA, then you can use v1.8.2 From the Manager window, select "WAV" tab, and upload a wav file. The file size must be less than 500 KB. Maybe you also need to update your core2's firmware to v1.8.2 using the M5Burner.
  • IR unit
    6k Views
    K
    @iamliubo Hi, Are you interested in writing a program for money? Two signals from the air conditioning remote control need to be recorded. Best regards
  • I'm unable to send data to AWS IoT
    9
    12k Views
    @ajb2k3 said in I'm unable to send data to AWS IoT: Did you try Rashibs guide? Yes, but it doesn't work. I tried with the AWS Python SDK and it works.
  • M5core2 No Buzzer/Beep options
    5k Views
    IAMLIUBOI
    Hi @ganeyvim , If you use UIFlow to do this, you can try this block: [image: 1628477476503-60f02e32-a5db-4554-b2a3-38f0936b42e6-image-resized.png] And arduino code can refer here: https://github.com/m5stack/M5Core2/blob/master/examples/Basics/speak/speak.ino
  • How to deal with Time DST (daylight saving time) ?
    5k Views
    Not sure if it works for this application, but in another project we used an API from google that returns current time anywhere in the world. Also as a general point, UTC+0 (Zulu) time is the way to go. It has no DST, and can be displayed as local time using an API such as the above to get the DST anywhere on earth on any day/time. https://developers.google.com/maps/documentation/timezone/get-started
  • Treat color as a variable?
    7k Views
    ajb2k3A
    Ahh I see. No, that just the way the blockly GUI options work in that you have to drag the UI element to the virtual screen to access the functions. Have you considered [image: 1627716157749-screenshot-2021-07-31-at-08.21.26.png] Which then creates a hidden placeholder line which then give you access to the functions? and then you create a function to create a line with a random colour. [image: 1627716829375-screenshot-2021-07-31-at-08.33.25.png] Edit Ahh I see, UI line and lcd line have different color functions
  • UIFlow M5Paper with RFID
    4k Views
    felmueF
    Hello @wwhite you'll need to click onto the [+] button (on the left, below M5Paper) and add the RFID unit first. Then it will show up in the Units menu. Thanks Felix P.S. If you do not see the [+] button you could try with a different browser. I have the best UIFlow experience with Chrome.
  • UIFlow use Uart data in Variables
  • My old m5f file could not open with new uiflow web why?
    6
    1 Votes
    13k Views
    felmueF
    Hello @world101 you are a genius. Thank you for the workaround. Works like a charm. Thanks Felix
  • Execute block in ADVANCED
    1 Votes
    6k Views
    AsmodevA
    I prefer the offline IDE as i may not have a connection to the internet, is there any way to download your online IDE for local uploading using a web browser?
