Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • GoPlus2 UIFlow Block
    5k Views
    R
    I also connected GoPlus 2 to M5 Basic. Next, I connected Relay Units to PortB_1 and PortB_2 respectively and confirmed the operation. UIFlow Block is based on the image posted by ajb2k3_san. I didn't have to use a block of Relay Units. [image: 1618134404005-m5stack-basic-with-goplus2-resized.png] [image: 1618134467310-pxl_20210411_094123026-resized.jpg]
  • Get NTP timestamp with COM.LTE module does not work?
    4k Views
  • How to change MPU6886 sensor range of M5 StickC by Arduino
  • Device hardware - revision
    3k Views
    ajb2k3A
    @garfield On the main pcb you will find the date printed. this will tell you the batch and sometimes the revision.
  • How to make RTC clock with NTP
    10
    28k Views
    D
    Thx @ajb2k3 - only that example does not appear to be applicable to the M5StickC.
  • UIFlow and deepsleep
    4k Views
  • More than one of the same units on an I2C-Bus?
    10k Views
    felmueF
    Hello @luex may I suggest you start small? (my apologies if you already have done that.) setup the build environment (Arduino, PlatformIO, UIFlow, ...) get familiar with your M5Core device build, download and run some simple examples (blinking an LED, put some text on screen, ...) now try to setup one watering/soil moisture unit using the provided example only if that all works try to setup multiple of them BTW: the watering/soil moisture unit does not use I2C to communicate therefore the discussion in this thread is probably not really helpful for your situation. Good luck! Felix
  • "\n" becomes "\\n"
    10k Views
    P
    @robalstona Tnx for the tipp. I'll try it.
  • (Solved)M5StickC+ToF:I2C bus error (19)
    7k Views
    felmueF
    Hello @Koms you are welcome. Thank you for reporting back. I am glad to hear you got it working. Cheers Felix
  • Pa.HUB in m5atom
    8k Views
    P
    @iamliubo Thank you :) I just noticed that it is already implemented. Thank you very much for that. It helps me a lot.
  • [Mac OS] Copy/Paste
    4k Views
    I found a workaround. Use the web version of UIFlow instead. Copy/Paste works great.
  • Blynk in UIFlow
    18
    36k Views
    A
    @ajb2k3 said in Blynk in UIFlow: I came across a video last night (lost link) that shows that it should be possible to run ESPnow and WIFI at the same time on an esp32. apparently all you need to do is to set ESPNOW to work on a different channel to the WIFI. @ajb2k3 Good hint. I will check my router to prevent using the channel I selected as common for the devices.
  • Dealing with background color changes ...
    6
    10k Views
    BTW, I created a new topic "randomness" with more detail on the issues I'm seeing. It goes beyond background color refresh...
  • Run mode is working, but not work uploaded program.
    4k Views
    IAMLIUBOI
    Hi @zoroaster , Sorry to hear this, can you provide more detail or the .m5f file for us to look at?
  • need help converting text to int (CORE2)
    13k Views
    T
    There's execute code block also
  • Separate firmware from M5burner
    10
    20k Views
    B
    @scottknight Hey hi, I just changed my chromebook to an Intel based one. But the ARM one did not even run M5Burner. So yes... if your CHromebook is Intel processor based, you can run m5burner. Thanks for the listing of directories for using the firmware directly with esptool
  • 0 Votes
    8k Views
    world101W
    @héctord It's actually the opposite as you describe. A higher layer takes visible priority. So when displaying text or shapes on the screen, an object on layer 8 is "on top of" (or covers over) an object on layer 3, and there is no transparency (see through). The tricky part is once you move your rectangle to highlight the next label, you have to redraw (or show) the changed areas of the screen. So the layers and screen management take some getting used to within uiFlow. Here is an example flow of what you are looking to achieve. Layers 0-3: reserved by uiFlow by default Layer 4: rectangle Layer 5: Label 1 Layer 6: Label 2 Layer 7: Label 3 Layer 8: Label 4 [image: 1615728311756-example-resized.png] Note: In the M5StickC UI simulator on the left, you could manually change Labels 1 through 4 to all be on layer 5 and it will still work, since those labels do not overlap.
  • can UIFlow export code to arduino code
    5k Views
    B
    Hey! hi, No. UIFLOW works with Micropython. In fact you are better off doing it from the beginning on Arduino, that is because the libraries are ready available there. And the code runs pretty fast because you dont load all UIFLOW api. Think of UIFLOW as a platform to make a proof of concept pretty fast, or to test something on the fly. UIFLOW is pretty cool for what it is, but has lots of constrains and not everything is implemented as of now. Also the cloud stuff is pretty mixed up.
  • ENV II Unit Support for UI Flow (device M5StickC)
    6
    12k Views
    ajb2k3A
    Under the picture of the StickC in UIFLow is Unit/HAT and a + sign. Click on HAT then click + and select ENVII to add the EnvII to the workflow. UIflow then automatically imports the needed libraries required to use it so all you need to do is add the blocks that appear in HAT>ENVII menu.
  • This topic is deleted!
