Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Upload .wav file to M5Stack Core2?
  • How can I write UTF8 strings in a labet?
    4k Views
    m5stackM
    maybe you could try to select unicode font.
  • can uart support irq?
    3k Views
    m5stackM
    Just like the mpy official document said. "Availability: Wipy". maybe future we will support this function, so pls give us some time. [image: 1624444172551-445f337c-fd4a-4f60-af15-495ba0b9608e-image.png]
  • Upload Code Failed
    8k Views
    C
    I am experiencing the same symptoms with my M5Paper and Windows 10. If I run and download an m5 file that contains about 1400 blocks it does not work, but if I delete the blocks to make it about 400 blocks it works. M5 paper This problem occurs with all combinations of UIFlow-Desktop-IDE (Win) v1.0.16, v1.0.17 and firmware versions v1.7.7, v1.7.8. A sample m5 file (about 1250 blocks, the event also occurs with this file) https://github.com/collelog/m5paper-dashboard/blob/master/src/weather-jp.m5f These m5 files used to be able to be run and downloaded in conjunction with UIFlow(Web), but UIFlow(Web) is no longer available, as shown in the following topic. https://forum.m5stack.com/topic/3361/uiflow-cannot-currently-connect-to-any-m5stack-devices
  • Re: [Upload Code Failed](/topic/3364/upload-code-failed)
    3k Views
  • Is there a way to reuse blockly code?
    5 Votes
    9k Views
    L
    I agree, it is sad. :( There is hope, however! I opened up one of the .m5f files that is saved from UI Flow to learn that it is a hybrid json/xml file with all the blockly code represented in XML. I'm thinking of working up a simple script that could be run in browser to parse this data and allow you pull single blocks and merge them into another file. The concept here is that you upload two files (library.m5f and project.m5f, for examples sake) and then you can pluck whole blocks from and to either file. This way your great new invention from project.m5f can be added to your library and your great work from the library can be added to your project. It will be simple, dare I say crude, to start with but should help. Also, I did tinker with making a custom .m5b file and it's not that hard but not quite the same as having a pre-built set of routines you want to use all the time. I'll post more info here once I have anything worth playing with.
  • 0 Votes
    12k Views
    ajb2k3A
    @robalstona thanks for sharing my book. @Serge hi, sorry been busy. I/O pins are 3v3 tolerant not 5V tolerant and no need additional components to protect them. The book was mainly based around UIFlow and M5Stack specific hardware but will have a look.
  • Once Function on demand in loop
  • http request to netatmo fails with error (solved!)
    11
    26k Views
    Hi is it possible to share you code ? interest by this code. for me the UIFlow not work with my M5 stack so I use only arduino ide interface. Thx
  • Is it possible to emulate without a device?
    7k Views
    S
    Many thanks @IAMLIUBO!
  • UIFlow
    5k Views
    IAMLIUBOI
    Hi @yo8ufo , Recommend you to buy CORE2 FOR AWS.
  • Uiflow-desktop-ide installation under Linux Mint
    5k Views
    IAMLIUBOI
    Hi @mikemuc68 , I use Mint too :) You can add this item to your menu. [image: 1621825848917-2021-05-24_11-08-resized.png] Hope it can help you.
  • MicroPython: handling multiple screens on Core2 with M5Screen()
    4k Views
  • HTTP POST to Azure IoT
    10
    19k Views
    P
    Just wanted to thank you for posting this. It helped me a great deal.
  • how to build UIFlow_Lite-v1.7.6.bin from source ?
    5k Views
    F
    let me show what we did: we use the CCI ISOBUS Stack, written in C, https://github.com/Meisterschulen-am-Ostbahnhof-Munchen/Install-ISOBUS-Environment/wiki ISOBUS makes GUI Communication ECU <--> Display over CAN, and much more for Smart Agriculture, which seems to be one of the Focus Topics of M5. i am a Teacher at School, and i want to Teach it in UIFlow instead of C, because easier to learn.
  • UHF RFID Anybody got this working, reading tags etc..
    4k Views
    T
    @ajb2k3 Hi. Yeah using the UHF blocks and have got UHF tags whose ISO matches that of the reader.
  • code example for remote control between two M5stacks
    8
    15k Views
    ajb2k3A
    You can send the values as a json string from the ROV to the remote and then separate the values from the sting on the receiving end. I am currently documenting this in my esp-now document.
  • Proper way to handle button (in hour counter)
    4k Views
    world101W
    @rosi Just add the “Button A wasPressed” callback (located in the Event blockly menu) to your flow and within that block, reset your counter values to the same as in the Setup function.
  • Core2: Python API to get battery charge level
    11k Views
    O
    Thanks. I checked on the Core2 and here battery voltage also ranges from about 3.2V to 4.2V.
  • UIFlow .m5f demo/repository/store call it as you want
    1 Votes
