Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • M5StickC HAT PIN control in UIFlow
    6
    11k Views
    world101W
    Unless I’m not understanding it correctly, according to the docs, you would select a pinX from the drop down list and type the pin number (ex: 26) into the Init pin block. Then you can get or set the pin via the other blocks. As far as pin0 through pin5, those seems to be a designator for the pin you are controlling. BAT = battery
  • UI Flow RFID Face - help needed
    6k Views
    C
    @m5stack I don’t think that would work, I need it to be written to the card in the raw hex value not in string, since it’s another system, that is going to read it, that will need the correct hex values and not the string converted one.
  • Ui Flow i2c scanner (Solved)
    6k Views
    C
    Solved it, it returns the result in Dec, and not in Hex, don't know if there is a way to convert DEC to HEX [image: 1586098055975-i2c-scanner-simple.png]
  • MQTT issues with UIFlow V1.4.5
    11k Views
    P
    @jcabad100 A) Even I am facing the same red "Connect Fail" error message every time I try to subscribe. I am using an M5Core Grey and cloudMQTT as a server. My intention is to send data from one M5 to another. The publish statement doesn't give the error whereas the subscribe gives an error every time. Can someone please help me with this? B) Also, can anyone tell me how can I subscribe to my M5 from cloudmqtt so that I can know if atleast publish works or not?
  • [Solved]M5fire read microphone
    Moved
    12
    28k Views
    I
    Hello, meanwhile it is possible to use the block "analog read pin (34)" from the blockpack "Easy I/O". So I was able to bild the probram from user M5DOCS just with UIFLOW. Unfortunally it just shows Numbers between 450 and 600 or so. And it dows not react to any sounds. This is the python code of the blockly program: ===== from m5stack import * from m5ui import * from uiflow import * from easyIO import * setScreenColor(0x222222) label0 = M5TextBox(122, 84, "Text", lcd.FONT_DejaVu24,0xFFFFFF, rotate=0) while True: label0.setText(str(analogRead(34))) wait_ms(100) wait_ms(2) What did I do wrong?
  • How to get the magnetometer values from M5Stack Fire by UIFlow?
    4k Views
  • Convert to Integer and test of integer give an Error (solved)
    9
    16k Views
    P
    @lukasmaximus Thanks for the tip. I hadn't thought of that. I thought I would have to construct my own block. Peter
  • Wrong Uiflow-Desktop-Ide version number
    3k Views
    m5stackM
    @fmentiplay the left top hand corner is the UIFlow firmware version. in the "Check update" option. is the Desktop IDE software version . they are diffrence
  • Support for node
    6
    11k Views
    m5stackM
    @ecasti ok. the desktop IDE will update the demo program in next version
  • MQTT subscribes on UiFlow
    23
    91k Views
    C
    @world101 Thanx! After making new topics and setting them to QoS=0, and retain=0, it finally works with many MQTT subscriptions on both M5Stack and M5Stick-C! (1.4.4 and 1.4.5) (PS! Just changing the old topics that had retain back to no retain, did not work, had to make new ones.)
  • recover m5 file from m5stack
    8k Views
    R
    @m5stack That worked! Thank you!
  • How-To: Using JSON & Map with MQTT
    4 Votes
    7k Views
  • GPS unit isn't work with M5Stack Basic
    4k Views
    lukasmaximusL
    It seems there may be compatibility issues since uiflow firmware version 1.4.0 http://forum.m5stack.com/topic/1388/gps-data try to downgrade your firmware and retry your code
  • Tiny WebServer crashes after some hours
    6
    10k Views
    lukasmaximusL
    great job
  • Uiflow HTTP request
    9
    28k Views
    J
    Thanks so much I totally overlooked the plus sign and I was searching for a block in the map blocks. I’m grateful for you answering my question.
  • Print % into label
    6
    9k Views
    m5stackM
    @m5stickfreakler Ok, I will tell the engineer these problem. Thank you
  • Speaker beep and Wait
    22
    65k Views
    M5StickFreaklerM
    @world101 said in Speaker beep and Wait: If you want additional testing help, you’ll need to post exactly what your entire flow/program looks like, including connections and Units. Obviously there is something unique in your setup that I don’t have, because it’s working for me. from m5stack import * from m5ui import * from uiflow import * @timerSch.event('timer1') def ttimer1(): speaker.sing(220, 1/16) pass timerSch.run('timer1', 1000, 0x00) --> It works if I download it to the device --> It does not work if I run it from UIFlow
  • Heart rate in uiflow
    5k Views
    S
    @m5stack Yes Heart rate sensor, sorry for my typo error. I will test it with arduino ide
  • what problem?
    4k Views
  • UIFlow Chinese translate
    4k Views
    sysdl132S
    [image: 1581169414267-9930c3a1-f06e-4aff-a276-ffcf561d6463-%E5%9B%BE%E7%89%87-resized.png] [image: 1581169437493-f8cacab2-0dba-41a3-b70c-25248d5060b2-%E5%9B%BE%E7%89%87.png] [image: 1581169458491-a3bde4b0-5f43-4f74-a2cd-9b045871c8b6-%E5%9B%BE%E7%89%87.png]
