Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Object has no attribute - Error
    6k Views
    felmueF
    Hello @RIDDSprojects you are very welcome. I am glad to read it works for you now. And thank you for reporting back. Best of luck with your projects. Thanks Felix
  • Pb.HUB with two digital read unit.
  • ATOM DTU NB MQTT Example dosn't work
    5k Views
    felmueF
    Hello @BennoB I can confirm that the UiFlow example doesn't work for me either. The block to connect to MQTT seems to be broken or not properly adapted for the SIM7020. @m5stack : please fix. Thank you. Thanks Felix
  • Webserver with UIFlow?
    11
    19k Views
    S
    What do you think? https://github.com/kotobuki/http-server-block-for-uiflow
  • Newbie UIflow questions.
  • How do i disconnect from the wifi?
    3k Views
  • This topic is deleted!
  • Missing info about emoji
    3k Views
  • Saving programs from UI Flow Web
    10
    11k Views
    W
    I have the exact problem: Chrome 107.0.5304.110 on Fedora 35. All buttons in the UI (label, button, line, etc) are nonfunctional as well as the "load", "save" etc buttons. UIFlow is completely unusable with Chrome. I can reproduce this in Konqueror also. The buttons seem to work in Firefox though.
  • ESPNow module not available. Alternatives?
    4k Views
    felmueF
    Hello @slow-moose which UIFlow firmware version is running on your M5Core2? I can use ESPNow blocks from the UIFlow online version 1.10.8 just fine on my M5Core2 running UIFlow firmware 1.10.8. You can use M5Burner from here to update the UIFlow firmware on your M5Core2. Thanks Felix
  • UI Flow cannot access local disk in Chrome
    3k Views
    ajb2k3A
    This looks like a running issues with google chrome as its happening (or not happening as is the case) with other sites that download files.
  • EspNow is receiving previous messages
    uiflow
    7k Views
    S
    I have same problem , after some time EspNow recieve callback block returns duplicate message. Uiflow 1.10.7 , firmware m5 tough 1.10.6
  • How to connect the COM.X NB IoT and use is for mqtt or other requests
    4k Views
    felmueF
    Hello @mchott in my experience a data SIM (for smartphones, LTE routers, etc.) is not good enough for NB-IoT. You will need a SIM card specifically for NB-IoT plus the NB-IoT service needs to be offered by the provider in your region. Thanks Felix
  • UIFlow and CAT M MODULE SIM7080G
    14
    22k Views
    felmueF
    Hello @teiafra thank you for letting me know. I am glad you found a workable solution. Thanks Felix
  • Firewall & UiFlow
    3k Views
    J
    Hello I've opened TCP 1883 and my device successfully connected. Regards
  • Core modules have rectangles/triangles in the UI designer, Core2 does not
    6
    8k Views
    ajb2k3A
    @teastain I try to be helpful!
  • [SOLVED] Execute code downloaded from MQTT/saved to EEPROM
    4k Views
    H
    I managed to solve this issue with this custom block
  • Save file on cloud (Gdrive, Dropbox)
    3k Views
  • Confusing Version control for firmware
    3k Views
