Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • UIFlow Source
    5k Views
    ajb2k3A
    I'm working on a book for the M5Stamp C3 using MP1.19.1 Going mainstream means a slimmer lighter faster MP but you loose access to the M5Stack specific libs and have to look for alternatives.
  • UIFlow - Micropython - USB plugged in
    5k Views
    J
    The python version of the c function looks like its probably not available: >>> dir(hardware.axp192.Axp192) ['__class__', '__init__', '__module__', '__name__', '__qualname__', '__bases__', '__dict__', 'deinit', 'setBusPowerMode', 'powerAll', 'setLCDBrightness', 'setPowerLED', 'setSpkEnable', 'powerOff', 'CURRENT_100MA', 'CURRENT_190MA', 'CURRENT_280MA', 'CURRENT_360MA', 'CURRENT_450MA', 'CURRENT_550MA', 'CURRENT_630MA', 'CURRENT_700MA', 'getTempInAXP192', 'getChargeState', 'getBatVoltage', 'getBatCurrent', 'getVinVoltage', 'getVinCurrent', 'getVBusVoltage', 'getVBusCurrent', 'setChargeState', 'setChargeCurrent', 'setLDOVoltage', 'setLDOEnable', 'setDCVoltage', 'disableAllIRQ', 'clearAllIRQ', 'enableBtnIRQ', 'setESPVoltage', 'setLCDBacklightVoltage', 'setLCDEnable', 'setLCDReset', 'setVibrationIntensity', 'setVibrationEnable', '_regChar', '_read8bit', '_read12Bit', '_read13Bit', '_read16Bit'] >>> However, I found two alternative ways to detect this, i2c being my favorite: https://imgur.com/a/nscmAHF
  • Wifi settings tutorial
    5k Views
    C
    Using buttons and labels you can draw a screen table and use it as an on screen keyboard in order to enter the SSID and Password .. [image: 1675362940447-e63945f5-0762-49b8-b380-39c36d386380-image.png] Pressing < > you scroll through the alphabet, with OK you confirm the letter... Much like setting and confirming your wifi credentials on an android TV When finished you connect to the Wi-Fi with the SSID and Password.
  • This topic is deleted!
  • UIFlox desktop on windows 7
    9k Views
    GulliverosG
    Hey there! I'm glad you're interested in using M5Fire and UIFlow in your workshop. It's always best to be prepared for any situation, and having a backup plan in case of no internet connection is smart. I'm sorry to hear that the UIFlow desktop download is only for Windows 10, but I might have a solution for you. Have you tried checking out websites that offer Windows 7 product key options for older computers? I found one website that has a variety of Windows 10 product key options for different devices, and it worked great for me when I upgraded my own computer.
  • UIflow and work with XML responses
  • Possible Problems with MQTT?
    6
    8k Views
    ajb2k3A
    If the Atom is not connected to the host computer as it is when testing, you will need to add the WIFI AP and Password blocks to the start of the program.
  • M5f files are "Not supported" on some devices.
  • Works with Chromebook?
    6
    12k Views
    C
    @m5stack Hey everyone! First post here. Is the full support problem regarding Chrome OS solved? I would like to know if I could flash a M5Stick CPlus on a Chromebook or not. As far as I've read, I can program one via browserbased UIFlow on Chromebooks only...
  • #!/bin/bash ./bin/uiflow-desktop-ide - MEANING PLEASE?!?!
    ajb2k3A
    The desktop version is not supported at present and not due to be updated until after UIFlow V2 is out
  • M5Stamp Pico API key too short
    9
    11k Views
    greenleafG
    For future viewers of this thread, the API key is the same as the MAC address. You can usually find this on your router config where it shows device info. The MAC is also shown in the serial output when you connect a burner device (or FTDI cable as mentioned above. My problem was the device was stuck and needed reflashing. Once I did that it worked perfectly using the 12-digit MAC as the API key. You may safely ignore the 8 digit "API Key" that is shown in M5burner or the command line, this was a red herring.
  • UIFlow .. multiple Weight Sensors with PaHUB?
    7k Views
    C
    I don't think the PbHUB will work ... The PbHUB can only handle analog and digital signals (no clocks !). Reading values from the HX711 weight sensor needs a clock and a data line provided by the ESP32 GPIO Ports ... The UIFlow HX711 library only supports Port B. If you want to use several weight sensors on the M5Stack you will have to hook them up to different ports and do the programming either in Python or Arduino using the Expansion Port Module getting the additonal Ports C D and E. P.S: If you want to hook up multiple Weight Sensors to a M5Stack using port A you have to use HX711 devices which can be hooked up to the I2C bus. M5Stack has no such modules nor units, but you will find one made from DFRobot (https://wiki.dfrobot.com/HX711_Weight_Sensor_Kit_SKU_KIT0176). This sensor also has a grove I2C port and by modifying the I2C addresses you can hook up to 4 Weigh sensors to Port A. Using the PaHub I2C-extender you can even hook up 6 to 24 Weigh sensors ......
  • How to switch off Core+GoPlus2
  • 0 Votes
    6k Views
    @felmue this worked in my case .. longPress and wasReleased
  • Looking for kind souls to adopt this aged brain and eyes.
    14
    16k Views
    ajb2k3A
    @dididada "...but these are not what I like to learn now. I like more basic stuff, like how to get the buzzer to play musical tune if it's possible..." Alas That I can't help you with as I'm tone deaf! Again, I will recommend you download my docs starting with the UIFlow Handbook and have a good read of them.
  • ESP-Now UIFlow to Arduino
    10k Views
    F
    @xio1996 I was trying to do the same thing. I have some ESP01 relay controlers, which they work fine between them aand an ESP32 WROOM. I'm now trying to use a Core2 as a master, but I haven't been able to communicate with the ESP01. Do you have any example codes for Core5 in MicroPython? Thanks in advance FBP
  • Linux Uiflow keeps flipping the com port btwn tty04 and ttySB0
    12
    12k Views
    D
    Ok, I am following with my post regarding the connection. First, I'd like to thank user 'ajb2k3' for trying to help. This is mainly user error, I saw the 'CONNECTING TO M5' flashing and the message just disappear' assuming that all was well and jump in to the mess. I wonder, what will it cost the system to have the 'CONNECTING TO M5' just hang in the loop, or issue a new message informing the users that he/she has not made a successful connection. I attribute it mainly to my carelessness. ASS U ME , always hurts.
  • ENV3 unit maybe not connect.
    5k Views
    D
    Resolved, the part that generated 'env3 unit maybe not connect' , I use the HAT (ENV) this time and don't get the error message. This, I still not sure that I blindly got it as I supposed to. Well, go on learning. Thanks.
  • Check if file exists on the SD card in UIFlow
    3k Views
    C
    I have upgraded my M5Go to 1.11.0, but there is still no change. There is no documentation on these sdcard functions at all: is this is the entire documentation? http://docs.m5stack.com/en/uiflow/advanced/sdcard This is rubbish.
  • How to save changes in UiFlow V1.11.0 on Core2?
