Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • CAN BUS Error with M5Stack and COMMU Module
    1 Votes
    4k Views
    E
    Solved with the code ;-) message = com.commu_can_read_message(0) hex_list = [] for b in message: hex_str = hex(b)[2:] if len(hex_str) < 2: hex_str = '0' + hex_str hex_list.append(hex_str)
  • Int to Float conversion
    7
    7k Views
    ajb2k3A
    Use the math function block to convert in to float then use a text block to convert to string?
  • UIFlow on Linux with Chrome not loading or saving Flow files
  • Unable to create simple EZData entries on M5Stack Atom Matrix
    8
    10k Views
    A
    Which firmware version are you using? | Experienced problems pushing data to EZData with 1.9.8 on Atoms. Reproduceable error not occuring after reverting to firmware 1.9.7.
  • M5stack Tough Mac Address
    4k Views
    R
    Hi @felmue . Thanks for the reply. I think I got the solution the same time you sent me yours. I did use the code in here as below: I did an 'Execute' Block: import ubinascii import network wlan_sta = network.WLAN(network.STA_IF) wlan_sta.active(True) wlan_mac = wlan_sta.config('mac') wlan_mac=ubinascii.hexlify(wlan_mac).decode().upper() [image: 1682625962466-76e881c1-37df-4e5b-94f1-c33c0da572aa-image.png] then a Label Block: wlan_mac [image: 1682626003960-147bf674-2e3a-4ea5-84fc-41c072d1ce42-image.png] Anyway, thanks for taking the time and effort to reply. Rami
  • REMOTE+ issues
  • I can't hide label with uiflow for M5 Tough
    4k Views
    R
    Try having them in a function! This is working for me [image: 1681584685879-hide-lables.jpg]
  • This topic is deleted!
  • Wire maximum length (Ultrasonic sensor)
  • CAN 1000kHz error
  • UIFLOW Modbus TCP
    1 Votes
    5k Views
    C
    I have the same question with the CORE2 ? Any update ?
  • How to parse this JSON format in UIFlow blockly mode
    3k Views
    ajb2k3A
    you use the JSON blocks in UIFlow
  • Initiating connection to AWS
    7
    9k Views
    ajb2k3A
    Combination of error 09 (authentication acknowledgment error) and OS error shown in the command terminal
  • Unable to connect Core 2 to UIFlow Web
    1 Votes
    4k Views
    ajb2k3A
    Reset your web browsers temp files and cache as it could be a cookie or something blocking it
  • Scale accurate to 10g only
    4k Views
    Thank you .. sometimes it´s just my hope to get an easy solution running and waking up in the middle of to many micro learning.
  • How can an atom lite listen forever to a mqtt topic?
    4k Views
    B
    On a side-note, this is the programm im running on a seperate atom lite using the same UIFlow version. It just sends a request every once in a while. My code:[image: 1678358578450-forum_publish-resized.png] May be somebody has some thoughts for this as well. Kind regards TD
  • How can I download my old script from a device?
    5k Views
    H
    You can use the "Device File Manager" in UiFlow. [image: 1678342098815-devman-resized.png]
  • Could you provide UIFlow release notes?
    Moved
    4k Views
    ajb2k3A
    They already do, there is an option in the menus to view the update log.
  • No documentation for UDP ?
